The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
SOURCE: LG washing machine displaying error
It's actually a DE error code which stands for drain error. Pull the
little basket out that's behind the small door on the lower left front
(where the drain hose is) and look inside. The drain pump intake is
about an inch in on the left. Make sure there's nothing in there like a
paperclip or hair pin. If possible reach in and see if you can turn the
impeller. If it won't move there's something in there if it will turn
then the motor is probably bad.
worked for me
got this from mark1963
SOURCE: what does oe mean on my washing machine display
"OE" code in your washer indicates a Drain error.
This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
SOURCE: LG Tromm Washing Machine Won't Drain code
Hi, //
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
