SOURCE: Can't tighten the handlebar stem.
hi lynduck,
are you using a threadless steam or a threaded one?
like this one in the picture.
http://www.sheldonbrown.com/images/headset-threadless.jpg
if so, spacers should be on the right spot and the pinch botls should be tights. top cap should not be moveable and this will make sure your front end turns lightly. apply light axle grease to make it smooth.
regards,
voodoo
SOURCE: can handlebar for ccm vandal
The threadless stem style you have pre-supposes you chose the right height and reach when you bought the bike. As the steerer tube to which it clamps has to be below flush with the top surface to accomodate the top adjustment cap, the steerer had to be cut to a final length that can't be made longer. The stem CAN be flipped upside down to provide a different rise and reach, but most likely it would be lower and farther away.
One option is to replace the stem with one with an angle and length that would work for you. Have a bicycle shop asist you in choosing one as there are 4 parameters that must be considered.
Another is to get a threadless stem riser which effectively makes the steerer tube taller. Google "threadless stem riser".
Here's one on eBay...
http://cgi.ebay.com/New-SATORI-HEADS-UP-Threadless-Stem-Riser-Adapter-1-1-8-/300530665912?pt=Cycling_Parts_Accessories&hash=item45f90609b8
SOURCE: How do I raise the
http://www.sheldonbrown.com/handsup.html Simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
