You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Fisher and Paykel WA37T26G Top
I noticed a little water at the bottom of my washing machine after a load was done. Can anyone...
(More)
I noticed a little water at the bottom of my washing machine after a load was done. Can anyone explain why that could be ?
I have a whirlpool washer and it wont stop filling with water. It fills to start the wash cycle and...
(More)
I have a whirlpool washer and it wont stop filling with water. It fills to start the wash cycle and as it starts to wash it continues to fill, to continue to over fill and floods the floor!
I have a Fisher Paykel Model MKT GWL 15 US Product #96200-A. I read the other solution for this...
(More)
I have a Fisher Paykel Model MKT GWL 15 US Product #96200-A. I read the other solution for this type of problem and it doesnt seem to apply to my problem so Im going to post whats happening with mine and hope for the best. Ive run it through an entire cycle empty with the door open so I can see what is happening. During the final spin water doesnt come from the sprayers directly in the center of the washer into the tub but from another hose that is off to the right (if your facing the washer) in the upper right corner of the inside. it doesnt put water into the tub but seems to put it on the edge of the tub and maybe run down between tub walls inside? It doesnt come out the bottom immediatly but when the tub spins the water is hitting the side of the tub and splashes water all over the lid (or me when I had the lid open) and then water also starts coming out from under the washer.it gets worse the faster the tub spins. I thought it might be coming from water hitting the lid but it does this even when I have the lid open. I checked the drain hose and everything there seems fine, full stream while draining before spin and all the way through the wash and it drains a little during final spinning. . I hope I decribed this well enough, I love my washer I just wanna fix it!
Where is the hot water wash? Hot water starts up, but cold water over rides the hot resulting in a...
(More)
Where is the hot water wash? Hot water starts up, but cold water over rides the hot resulting in a cold wash. We want a hot water wash. So far the sales people and techs haven't been much help.
