Samsung Galaxy Tab 3 SM-T210 8GB 7" 1.20GHz 1GB Android 4.1 Wi-Fi Tablet - WHITE Logo
A
Anonymous Posted on Oct 20, 2014
How do I log into my google sccount using a samsung tablet sm-t210-r
I get an error message: try another wi-fi network or try later
cirrus
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Oct 24, 2014
cirrus
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
1351
Points
11
In setings of tablet look for something akin to 'accounts' see if you can log in there, if not simply open the app gmail or play store and login through the app
good luck
1 Related Answer
Kris
  • 73 Answers
  • Posted on Aug 29, 2011
SOURCE: have a samsung galaxy tablet
Have you tried holding the power button for 10+ seconds? or can you remove the battery?
Testimonial: "thanks tried holding power button longer but it workede thanks"
How can i use my samsung galaxy e tab out side my home or anywhere i have wi fi
If the tablet only has Wi-Fi then you can only use it where there is an "access point" or an open or public Wi-FI network. You can use it in private networks if the administrator give you the password. Some tablets have a cellular device built-in and need a SIM card to activate, but the Samsung E model does not.
Go into "Settings" (the gear icon), then into "Connections" and into "Wi-Fi".. You will see all the nearby access points or networks in order of the signal strength (number of curves). It there is a small lock below the curves, then you need a pass word to get in. Just select the network name you want to connect to.
I factory reset my zeepad, 7DRk-Q. Restarted the device. Wont let me sign in to any google apps.
Please make sure you are connected to your network. Let us know? Thank you. Please leave feedback
How do i take a screen shot on my SM-T550?
Samsung Galaxy Tab A (Wi-Fi, SM-T550) - Taking a ...
? 0:59
https://www.youtube.com/watch?v=u7nPrI5BG10
Jun 4, 2015 - Uploaded by SPSN
Capturing a screen shot is quick and easy on your Samsung Galaxy Tab A.
Taking a Screenshot - Samsung Galaxy Tab A (Wi-Fi, SM ...
www.samsungsupport.com/spsn/detail.jsp?ctg_id=1280...id...
Taking a Screenshot - Samsung Galaxy Tab A (Wi-Fi, SM-T550). Capturing a screen shot is quick and easy on your Samsung Galaxy Tab A. facebook twitter.
Samsung tablet will not accept wi fi password,the model is sm-t330
first forget the wi-fi network than try again manually .
How do get wi-fy on my tablet?
It's a good idea to access Wi-Fi whenever possible to avoid data charges. After you've activated the Android tablet's Wi-Fi radio, you can connect to an available wireless network. Obey these steps:
  1. Open the Settings app.
  2. Choose Wi-Fi.On some Samsung tablets, you find the Wi-Fi item on the Connections tab. Choose Wi-Fi to view a list of available Wi-Fi networks on the right side of the screen. Otherwise, the list shows up full screen.
  3. Choose a wireless network from the list.When no wireless networks are listed, you're sort of out of luck regarding Wi-Fi access from your current location.
  4. If prompted, type the network password.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
  5. Touch the Connect button.
    The network is connected immediately. If not, try the password again.
When the tablet is connected to a wireless network, you see the Wi-Fi Connected status icon. This icon indicates that the tablet's Wi-Fi is on, connected, and communicating with a Wi-Fi network.
Some wireless networks don't broadcast their names, which adds security but also makes connecting more difficult. In those cases, touch the Add icon. This icon might also be labeled Add Wi-Fi or Manually Connect. To make the connection, type the network name, or SSID, and choose the type of security.
You also need the password, if one is used. You can obtain this information from the girl with the pink hair who sold you coffee or from whoever is in charge of the wireless network at your location.
  • Not every wireless network has a password. Still:
  • Be careful when connecting to a non-password-protected network. It's possible that the Bad Guys can monitor such a network, stealing passwords and other information.
  • Some public networks are open to anyone, but you have to use the web browser app to find a login web page that lets you access the network: Simply browse to any page on the Internet, and the login web page shows up.
  • The Android tablet automatically remembers every Wi-Fi network it has ever been connected to and automatically reconnects upon finding the same network again.
  • To disconnect from a Wi-Fi network, simply turn off Wi-Fi.
  • Use Wi-Fi whenever you plan to remain in one location for a while. Unlike a mobile data network, a Wi-Fi network's broadcast signal has a limited range. If you wander too far away, your tablet loses the signal and is disconnected.
What are wifi networks when setting up tablets
The wi fi networks are whatever is available in your home or public wi fi network. If it is a free wifi network then simply select it from your tablet and it should connect you up. If it is a secured network then it will prompt for the code that has been set up.
Check the manual on page 28.
http://downloadcenter.samsung.com/content/UM/201401/20140109103000843/SM-T210_UM_EU_Jellybean_Eng_Rev.1.1_130523.pdf
My Samsung galaxy ace sm-s765c won't support any Wi-Fi Hotspot app's, what do I to fix the problem? I'm just trying to put some games on my sons tablet, but it won't connect to my phone without Wi-Fi.
You have to have wifi there is no way around it . Do you get a error message of some kind if yes .i need to know exactly what. Beause if you using any other browser then the regular round globe your hot spot wont work.
Unable to switch on my samsung T210 tablet
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Network error message using google search
You need to register this device to the app store
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
