Question about Motorola Mobility RAZR V3x Cellular Phone
V3x hanging and slow menu options
Hi, I have a V3x which all of a sudden is struggling to find service and drains the battery very quickly and when I try to view a video it hangs and I have to pull out the battery to reset. Also, by far the most annoying part is that when i navigate through the menu I have to be one step ahead of myself cuase the last menu won't come up until I have pressed up or down on the next menu (in otherwords it is extremely slow). I have reset the phone to it's original settings and deleted everything with no difference at all.
Hi, we have the same problem with the same motorola unit.. i've cause a lot of money looking for the solution on this problem & the best thing was i got a solution on it. 1st suggestion is look for a expert technician that will reformat your v3x then ask the tech to check your camera and the ribbon if there is a defect, 2nd, let the tech diagnos your phone to look for the correct problem of your phone.. This thing happen to me already & thanks for the great technician i got & he make my v3x unit as good as new again.. never stick to one technician, always ask the opinion of the another technician, this is the best thing i did..
Posted on Nov 13, 2008
How can reset my motrola razer v3x without secret code plese help me
Hello, You can perform a master reset to dissolve any glitches, bugs or other complications you experience with a Motorola Razr V3x. According to the device's user guide, a master reset will reset all options in the phone, with the exception of the "unlock code, security code and lifetime timer." Back up any data, pictures, or contacts you wish to keep before performing a master reset on the Motorola Razr V3x
1 Navigate to the "Settings" menu using the directional arrows. Click the "Setting" option with the "Center" key on the phone. 2 Press the "Center" key to choose "Initial Setup" from the Settings menu. 3 Press the "Center" key on the keypad to select the "Master Reset" option from the Initial Setup page. Thank you for using Fixya
Dec 28, 2010 | Motorola Mobility RAZR V3x Cellular Phone
The motor is screeching and barely moves. Started periodically, now is constant. Drains fully charged battery within minutes.
When the motor is screeching and draining the battery, that indicates that the motor has most likely seized up and is not turning the axle properly, which in turn will drain the batteries quickly as the scooter struggles to move. I strongly recommend discontinuing use of the scooter for your safety until the motor can be replaced; contact the manufacturer for a service call to fully diagnose the problem and give you a quote. If your insurance purchased the scooter for you, they may partially pay for the repair.
Dec 19, 2010 | Golden Technologies Buzz Around 3 Wheel...
Its very slow in processing any thing
Try these codes:
*#3370# - Enhanced Full Rate Code (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370*
- (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
Nov 09, 2010 | Nokia 5800 XpressMusic Smartphone
Slow slow drain battery very fast
If I'm understanding your question you are losing your battery quickly. Go to the Market and download an app killer. All the apps you run take an amazing amount of battery. The app killer is just a quick pulldown menu thats lets you select which apps you want to turn off all on one convenient menu. The moment I did it I noticed a huge savings on my battery. Another easy fix to help extend battery life is to turn down the brightness level on your screen to the lowest level you can tolerate. Should help out a lot by doing both of those things.
Dec 23, 2009 | HTC G1
Problems with my motorola v3x
if the display on your screen is only half of it, it means that the theme installed in your fone is not for motorola v3x.
with regards to the backlight, the connector from the lcd to the board is loose.
if you can only see the white light, it means that your fone is running an application, loading or hanging up like what's happening in pc's.
i think you need to master reset your phone and put only a 256memory card. even though it is said to carry up more, just stick with the 256 memory to avoid those problems.
Oct 28, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Finepix A340 suddenly started draining battery really quick and every time plugged into USB post comes up device not recognised
there is most likely a mainboard problem in the device witch is draining the battery, try difrent usb ports, the camera might require service.
Apr 19, 2008 | Cameras
Sudden switch offf....................
Hi. 1st u go urs mobile setting and restore ur fectory setting its code is 00000.
Mar 06, 2008 | Motorola Mobility ROKR E6 Smartphone
How do you change txting style?
Menu>Messages>Create Message>Options>Change Text Mode#>Secondary. thats how i change it on my one.
Nov 13, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
546 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
