Opening up the GUI:
1) Open up any browser
2) Put 192.168.1.254 in as the URL and hit enter
3) Search for wireless settings
4) Change channel to any one except 1,5,11
Note: If it asks you the for the Network Device Code, that can be on the sticker on the side of the router.
I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to
rescan the channels (it could be that the TV has the other channels
hidden (or lost the list).
1. Manually turn on the device (TV or Cable box) to be controlled. 2. Press and hold the P (Program) button until the red indicator stays on. Release the P button. 3. Press and release the desired mode button (TV or Cable). The red indicator blinks, then stays lit. 4. Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channels. If you accidentally overshoot the desired code, press the Channel Down button to backtrack through the library until the device changes channels. Pressing Channel Up changes the direction to forward again. 5. Press and release the Enter button to set the code. If the device does not have a Channel Up button, use Power instead. If you go all the way through the code library without finding the correct code the indicator blinks a few times then goes off.
go into the menu of tv find the option to auto program- let unit go thru process without interupting it.now chanels up&down should work-the problem was there were no chanels in its memory
in side the mother board(kit) there should be vertical IC gone. check the vertical section for the IC number and replace it , this will solve ur problem
To change channel & code press talk and monitor
while turning radio on.
Radio will speak current channel.
Release both talk and monitor.
Press talk to change to next channel or press
monitor to keep current channel.
Press monitor when desired channel is selected, radio will speak current code.
Press talk to change to next code or press monitor
to keep current code.
Press talk to change code as desired then press
monitor when done.
Will speak channel and code selected.
Set all units in same manner to
communicate.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
1. hold in "code search" till light stays on
2. press channel up until tv changes channel 3. press enter as soon as channel changes note: if you pass the right code just use channel down to get back to it
