Unfortunately it may be necessary to order the complete carafe. You may wish to try contacting Cuisinart using their web inquiry form to see if they are able to provide the lid as a separate part:
The lid is pulling down by either left or right actuator causing the lid seal touching your tube. In running mode these 2 actuators pulling down the lid to seal the tube so no water leaking. When the cycle is completed, the actuators push the lid up. In this case one of them is bad not pushing the lid up. The actuators are not hard to replace. When you order, it comes with a pair, replace both. Inspect the lid, if the seal is damaged, you can order the lid to replace together.
Yes, there is a replacement lid available for your pot. I am including a link that will take you directly to the Rival Crock-Pot parts page where you can order the part online or through Customer Service.
After being asked to call a number of different phone numbers, I was finally able to order a lid for this from the company that manufacturers this slow cooker for Sears.
1-800-361-4639
$25.90, shipped to the US (the company is located in Canada) for the lid.
The part # is: 1003kj.
Note that the Sears model number for the slow cooker is KKC275.
The Sears item # is 68332 (even though the plate on the cooker and manual both say that the MODEL number is 68332).
I called Select Brands at 913-663-4500 to order the replacement caraffe for this coffee maker. Their email is [email protected] The website is under construction so orders cannot be placed online. I broke my coffee maker yesterday and still have my lid - guess I'd better keep the lid....
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
