Starts to print and then just sounds like it is turning but not printing anything. It has been calibrated and worked, but it won't print from word or google.
SOURCE: Won't print a whole page
Try updating the printer's firmware from the Kodak webiste.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
SOURCE: Kodak 5500 All in One Printer
Error code 3809 refers to the printhead. You may try reinstalling it to make sure that is not the problem. Take it out, reinstall it, disconnect power cord from back of printer and wait for 2 mins. Then, re-connect power cord and wait until the memory card and photo tray lights go off. Turn printer on. If not solved, contact support
SOURCE: calibration not working
When you place the calibration sheet on the scanner glass, make sure you put it with the blue arrow facing the yellow triangle on the scanner. (the page must be, obviously, facing down).
As with the red color issue goes, try replacing the color ink cartridge. If that does not work, contact kodak support to fix the problem (you can go to kodak.com/go/itg for troubleshooting steps)
SOURCE: calibrating 5100 kodak all in one easy share printer
Go to the printer maintenance program and select "Calibrate printer".
SOURCE: printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
