Beko washing machine programmer
Programmer doesn't accept the program you turn it to, it just spinsback round to the end of the selected program,making a clicking noise as it goes through each segment of the program.Help
SOURCE: Beko WMA 1715S
try unplugging and let it reset itself
Posted on Apr 03, 2008
SOURCE: Beko 6152 washing machine
u havte to buy new
Posted on Oct 31, 2008
SOURCE: I have a beko WMA
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Posted on Dec 07, 2008
SOURCE: Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Posted on Jan 03, 2010
  • 15935 Answers
SOURCE: beko washing machine main wash led flashing
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
SOURCE: Beko eco care WMA 10W: The washing is always very
eko eco care wma10w is making loud noise when on full spin, have looked at belt seems to be fine
Posted on Dec 05, 2010
0 characters
1 Points
What is error code E3 in washing machine Beko 91242 LC
This error code is below. Good luck to you:
Constant heat
Nov 25, 2014 | Beko Washing Machines
Why wont my beko washing machine will not fill up with water when put on a wash cycle what can the problem be
If you are able to select the program and the ON button is accepted but no water then either the water inlet tap is shut off or the water inlet valve is faulty. Need full model number to provide more information.
Sep 04, 2014 | Beko Washing Machines
How to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
Feb 07, 2012 | Beko Washing Machines
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
Mar 13, 2011 | Indesit W 123 Front Load Washer
Programmer sticks before the spin cycle (number 5 and 9) on my beko washing machine also if you change programmes the programmer jumps round
Prog jumps as it will carry out 1st command selected unless reset.the sticking could be a faulty water solonoid valve if this happens say during softner fill although could also be the timer /programmer at fault
Apr 03, 2010 | Washing Machines
Nov 19, 2009 | Washing Machines
Apr 11, 2009 | Washing Machines
Beko WMA 1715S
Apr 03, 2008 | Washing Machines
Washing Machines Logo
724 people viewed this question
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
