6 Volt System, Houses Wirering Harness, Black Or Chome
SOURCE: Will an XT350 (1985-1995) rear brake pedal fit a modern 07 XT 125
try ebay or a motorcycle salvage
SOURCE: 88 honda ct110 6 volt system. 8 volts at headlight
sounds like the new used one is bad too. The only thing that regulates voltage is the rectifier.
SOURCE: I just put a new battery in my 1977 yamaha 650 .
It takes a 12 volt YB14L-A2 battery, which is large by modern *** motorcycle standards. There should be a 20 amp in -line fuse on the the small wire attached to the main battery positive wire. Blacked? Is that computer geek terminology?
SOURCE: bought a '01 Honda CRF100F trail bike. No manual.
Use 10w40 in the gearbox. DO NOT use a synthetic lubricant or any oil with "Special" additives. They can mess up the clutch. Any national brand motor oil will do.
