I have had a samsug idcs 18d for years and it works great. today, when I puch vvmsg to get my messages,it does not prompt me to "enter my password" and does nothing. so, I can not pick up my messages. what do I do?
SOURCE: recording main message
trying to recorded a different main message to phone, how do you do it?
SOURCE: Samsung iDCS 18D
Dial transfer, dial 505.
You'll be promted to enter the new date and time.
Dial transfer to save and exit.
SOURCE: Cannot set the time and
HI, i got
the scoop on how to change the date and time. first while handset is
on hook press TRSF then dial 200 Dial 1234 the display shows enable
cus prog dial 1 to enable then press TRSF To change the date and
time from here out press TRSF and dial 505 the display will show :
(this is an example)
old: 6010104:0047
new:WMMDDYY:HHMM
Enter the new time and date using the above format and the system will
return to step 2. Verify the time and date and re enter if necessary
Press TRSF to store and exit. or press SPK to store and advance to the
next program.
Hope it helped....
Good luck..
SOURCE: How do I program buttons
Hi I have posted a video off http://www.abbeytelecom.com showing how to do the soft key programming, a tip is when programming the transfer to voicemail - it shows as VT *** ( voicemail group number).
SOURCE: We are running on Samsung iDCS 28D and 18D phones,
Hi, I recommend that you find a reputable Samsung Telecoms Maintainer, you can do this on google, the problems that you could encounter are not worth it, you are far better to do this and get it programmed exactly how you want it, regards Al
