2006 Chrysler 300 Logo
Anne Laro Posted on Oct 20, 2014
My chrysler 2006 300c has had the navigation system/radio system replaced,as well as a new nav cd.The nav works sometimes then you stop shut the car off and it wont work.It works about 50% of the time
My chrysler 2006 300c has had the navigation system/radio system replaced,as well as a new nav cd.The nav works sometimes then you stop shut the car off and it wont work.It works about 50% of the time. I have seen the code P1 come up at times,any suggestions would be greatly appreciated. :)
A
Anonymous
Dealer & spend more money than you want to
5 Related Answers
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Jun 11, 2008
SOURCE: BMW 530i Sound not working on Audio
This is because of the cs changer which is mounted in the boot of your cars , this happens when there is any vibration in the car or the wiring is shorted please get it checked .....................
good luck..............
Anonymous
  • 341 Answers
  • Posted on Dec 15, 2008
SOURCE: Turn signals sometimes don't work
Change the flasher to an electronic unit. They are far less likely to give you trouble.
Anonymous
  • Posted on Apr 12, 2009
SOURCE: Locked renault clio 2001 cd/radio player!
to enter your code when the cd player displays error leave cd player switched on and after 20 mins or so i will display 0000 then you will be able to enter your code this happens when some 1 has entered the wrong code
david4411
  • 98 Answers
  • Posted on Aug 09, 2009
SOURCE: 2005 chrysler 300 radio/nav system problem.
it is an internal problem in radio
Anonymous
  • Posted on Oct 26, 2009
SOURCE: denso navigation problem
I had the same problem, and then I figured it out. I unhooked the dvd rom opened up the unit and noticed there were resistors on the board which were burned out and the inside of the housing showed slight signs of oxidation. I came to the conclusion that since the unit was mounted in the trunk the unit malfunctioned from water intrusion or moisture, which shorted out the board. Now I'm searching the web to see if I can find a Denso repair facility.
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
The built in sat nav screen keeps going up and down without switching on and also the radio cd does not switch on. any advise would be appreciated
bmw navigation radio cd changer repair
www.hitechserv.com/electronics-repair/oem-navigation-dvd-cd.../67
We repair all models of BMW GPS CD Changer Stereo ... shows on the screen, no audio, display shows no navigation disc but there is a disc inside, do not play CD. ... If there is sound but your blue tooth or satellte tuner is not working "if your car is equipped with blue ..... The MK3, MK4 computers has a GPS module built in.
3 Series (E46) built-in Sat Navs - Gassing Station - PistonHeads
www.pistonheads.com/gassing/topic.asp?t=862860
PistonHeadsJun 9, 2010 - I don't know much about the OEM sat navs, other than that they cost no less than ... would need to be re-positioned and CD player becomes redundant. ... on forums, they do the job, just about and sometimes not too well at all.
Navigation screen goes blank (I think it's there to stay now) - radio, CD play, but when blank will not change to another mode. When in radio , can change between stations on the same frequency only. ...
Very hard to diagnose nav /stereo units. Check fuse box to make sure it's getting a good power supply. Try spraying WD-40 or contact lens cleaner in the switches to see if any of them are stuck. Consider replacing entire unit w/ one from eBay, preferably with some kind of warranty. Also, check Crutchfield.com for new alternatives. A factory replacement, if you can find one, is likely to be really expensive.
1helpful
4answers
Radio/nav system dead
I have 2010 Porsche Cayenne and Nav screen just goes black and turns back on - sometimes it does it few times a day sometimes its working fine ..any idea?
1helpful
2answers
I purchased a 2002 Range Rover Borrego recently.
I have experienced many electical demons with all my British cars. The nav units can and do fail. I had a goofy one this summer and the only way it got fixed was to replace it. The module not the head unit
3helpful
2answers
MBZ E320 CDI (2003), The CD, Radio and navigation system not working. The car battery became flat after having my car parked for 35 days, so I jump started the car and it started fine. But the CD, radio...
Your radio/nav system needs a code. Go the your dealer's parts department , give them the VIN of your car( should be free $0). Punch in the code through the car radio and your radio/nav system should work right away.
2answers
Can't get navigation and cd player to work
You can purchase the manual from the dealer. You need the disc for the nav system to program it. Another is you may need to have a code to operate the nav. Did you press the mode button to go from radio to cd? Try to detach the negative battery or press the reset button to factory default, this will bring you back to the factory settings. It looks like a small hole on the radio face. You must use a fine point to push it in and reset it. Is a cd stuck inside of the cd slot? Do all your trouble shooting first and you will find your answer......runjoe
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
