Garden Logo
A
Anonymous Posted on Oct 20, 2014
How to pull off sleeve strut seal on a polaris
How to pull off sleeve strut seal on a polaris 1990 trailboss 350l 4x4 front end.
Stan Ford
Level 3:
Genius:
  • Master 3,131 Answers
  • Posted on Oct 20, 2014
Stan Ford
Master
Level 3:
Genius:
Answers
3131
Questions
Helped
903980
Points
9078
Some struts are sealed and cant be repaired. others have a large nut on the top can be removed with a special tool.
1 Related Answer
Anonymous
  • Posted on Apr 09, 2010
SOURCE: 1992 polaris trail boss 4x4 not engaging
replace button under the high and low lable on the shifter..... the shifter automaticaly pushes these buttons when put into gear
'93 polaris trailboss 350l What are the symtoms of a bad exciter coil? The manual says it should read 120 ohms tester reads 115 ohms is there any leeway in the reading, or must it be exact?
115 ohms is less than 5% of 120 ohms. That part of your check is OK.
If it cranks on starter fluid, your problem is fuel related. Stopped up fuel filter. Dirty carb.
Hesitation and lack of full throttle are symptoms of lack of fuel to engine.
93 polaris trailboss 350l 4x4 new piston and rings ....no suction at carb
This is not enough info to start. ..Hold the palm of your hand over the back of the carb and make sure its sealed against it... You need a helper to do this properly. The engine should pull on your hand inwards... if not....??
Did a shop or factory trained mechanic do the work? Are the reed valves able to open and stay closed? What does the compression gauge read? If you don't have one, beg borrow, buy, and/or take it to a shop and pay them to check it. Check it with the throttle wide open... with new piston and rings it should pump over 120+psi. ..easily.
Have the compression checked and then repost with the results.
Thanks!
May 28, 2017 • ATVs
How do you remove the thermostat from a 93 Polaris trail boss 350L 4x4
DOWNLOAD POLARIS TRAIL BOSS REPAIR MANUAL
trailboss-manual.blogspot.com/
Nov 5, 2014 - 4x4 free printable 1989 polaris trail boss 350 2x4 parts 03 polaris 350trail ... engine diagram trail boss 350 4 stroke diagram how to test the thermostat ... apolaris trail boss 1994 350 shop manual for 1993 polaris 4x4 trail boss ... boss 350oil pump repair manual for polaris trail boss 1987 removing jets in ...
Sep 25, 2015 • ATVs
2helpful
I have a 1990 trailboss 4x4 polaris i put new rings and pistons in it started for a minute then quit its getting fire what could be wrong
everything could be wrong, wrong size piston, rings, but most likely you have a timing issue. since it ran at first and I don't know how well or long it could have jumped time or broken the tensioner for the chain. but if it was slightly off you probably bent a valve an it is staying open slightly preventing compression. pull out your plug and put your finger over the plug hole to check the compression. if no compression then you bent the valve.
Dec 09, 2014 • Garden
Why when my polaris trailboss 250 is in neutral and off I can only push it backwards but not forward plus I have a good stator and cdi why don't I have spark
Chances are you broke something and hopefully not in the motor. I would use an atv lift and raise the wheels off the ground with the bike in neutral and try to rotate each tire in both directions to get my first clues. If 4X2, then the front tires should be free to rotate and your focus is only on the rear wheels. Both wheels should be locked together and neither rotate differently. If 4X4, then all 4 wheels may be engaged and locked, depending on the nature of the quad if on-demand or not. Next, you may need to disconnect the drive shafts from the transfer case to determine if front and rear cases are each freely rotating. I once busted a drive shaft on my 4X4 polaris and removed it in the field using a phillips head screwdriver to knock out the roller pin so I could pull the splined end out. This freed up the other side to power me out of the woods.
Point is, disconnecting one drive isolates the other side in case it help pin point the issue as outside the motor. Let me know how you do.
Jul 13, 2014 • Polaris ATV
I have a 93 polaris 350l 4x4 revved engine and lights blew also th cooling fan stopped working around the same time
I have a 2001 polaris scrambler 500 4x4 and it wouldn't charge the battery and my lights wouldn't work and the fan wouldn't come on so it overheated and it was the voltage regulator that was broke and that makes the fan and lights work it might not be a stator hopes this helps
Jan 24, 2013 • Polaris ATV
4x4 dont work 92 polaris trail blazer 350l
I think it might be the contact discs in the front hubs, they wear rather easy and cause you to loose 4x4
Jul 08, 2009 • Polaris ATV
Top Garden Experts
Jay Finke
Jay Finke
john h
