Question about Panasonic NV-HD680 VCR
Code F13 It displays 'F 13' when the VCR is in Stand by mode. What does it mean?
  • Bhupinder Nov 16, 2007
    Just wanted to add the that the VCR works fine otherwise with no problems. The F13 code disappears when it is turned on. The code appears only in the standby mode.
  • Anonymous Dec 21, 2007
    Problem Solver:
  • 10 Answers
It's sounds like the vcr's tape mechinisum is malfunctioning to me. Try unpluging it for a while. It will correct itself. Or it might have
dew sensors if the room is too cold the vcr wont work until the dew it gone off the heads. If it don't have dew sensors
and plays the tape with dew on it might eat the tape.
also if a timer is overlaping or is set to come on right now it might do this.
Posted on Nov 13, 2007
What does code F-13 indicate?
Why is my Kenmore oven giving me an F13 error code ... > kborders06 > Questions
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad.
Sep 08, 2015 | Kitchen Ranges
Frigidaire fault code f13 kitchen range what does that mean ?
Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
Jan 13, 2015 | Frigidaire Kitchen Ranges
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Dec 15, 2014 | Tappan Kitchen Ranges
Will a fridge still work if fault code 13 is displayed?
13 error code means heater element in freezer drain bad replace have to take apart whole freezer
Aug 12, 2014 | Thetford Refrigerators
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Aug 01, 2011 | Kitchen Ranges
Getting an F13 error message on my stand alone professional series oven smooth top, how can this be corrected?
F13 does indicate you need to replace the electronic oven control. It means EEPROM/ Checksum error. If you have unplugged and it returns, this is a bad control board.
I hope this helps.
Apr 21, 2011 | Ovens
I have error code f13, can you help, please..
This s is how i fixed the F-13 Fault on my Hotpoint WD 640 washer dyer. Simple to fix just see the pictures and explanation. Hope this clears things up
Aug 07, 2010 | Dyson Memory CRO1 Front Load Washer
F13 flashes on my Frigidaire electric range
Control's internal memory may have
become corrupted.
1- Press Cancel key.
2- If fault returns disconnect power, wait 30 seconds and
reapply power.
3- If the problem persists upon power-up replace the display
Sep 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
The machine quits after a couple of minutes and displays a flashing 13 followed by F
take the kick panel off there are 3 torques 15 screw or 7 millimeter. remove them and on the left side you will find the tech sheet find out what f13 means and let me know.
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Panasonic NV-HD680 VCR Logo
358 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
