The Holden VE SSV ute range has a problem with not being able to drive the car hard through the gears in the manual due to an apparent lack of fluid getting back up to the master cylinder which is due to the clutch fluid restrictor that holden introduced to cut back on syncro damage .
SOURCE: How do I remove the gear knob from a manual Holden
think it just unscrews if its the same as a opel astra
SOURCE: holden ute on dedicated gas wont start
It sounds like the timing is out if it it is backfiring and now wont start reset the timing and your problem could be solved
