Hi All,
My system Processor is working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem. My system Configuration as mentioned below.
Also provide me a solution ,How i can Enter in System BIOS, To Restore Factory Settingsor Default Settings,(when system processor is working But not displaying anything)
iam sekhar having an intel 845gvsr motherboard with 256MB ram,but i want increse my ram 1GB and which RAM will support my motherboard and give me the latest version of this series,and now i am using DDR ram and if i need to upgrade to DDR 2 ram,is it support to my motherboard are not and witch part no will support my PC.
Intel Desktop Motherboard 845GVSR the problem no display but the ram is ok, when i remove the ram on the board, then on 3 times beep, so how to fix this?
Hi All, My system Processor is working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem. My system Configuration as mentioned below.
Show your appreciation by commenting on Intel 845 GVSR:
Solution #2
posted on Nov 11, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
Hi Alex,
I would appreciate your solution as one which I was wanting to get. I was battling with my board with same chipsetr features. My motherboard with 81845-GV chipset faced the same issue suddenly. When I boot up the system light powers on but no display nor any beep. sounds bad. I have no idea whether it isa board or a processor as I tried the SMPS with other pc which worksfine and even checked the voltage output of the smpswith a multimeter. still with the board and cpu no idea how to check it.Moreover the graphic card and pcicard are inbuilt. I am just a novice on these but i managed to check some. The url which you have given will be very helpful for novice engines like me.
Thankyou in advance.
But dont stop your replies it may be helpful to many like me
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Feb 25, 2008
Guest
my smps & processor are working but qhen i connect with board fan are not runing (smps & processor ) only green led light is disply on bord how to determine the problem give me solution
Solution #4
posted on Feb 08, 2008
Guest
My friend is having MB - intel 845gvsr
till yesterday it was working fine BUT after a sudden power loss it stopped working
There's no display in the moniter.Not even the bios CP
When the power is supplied to the CPU the processor fan is working fine
No beeps,CD ROM /Tray etc are working fine
If BOTH the 256mb ram module is removed then it is giving the beep signal So there's no problem with the BIOS
So where is the problem ?
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Then go ahead and make your own post for this particular device so that it can be answered appropriately.
Here we either answer for money or ratings. We can't get ratings from posts that are attached to other posts. :P
Good luck either way. I have two of these boards running servers and
if I see your posts, I will also attempt to help you as Alex did.
(Which from what I see there, it should be a SOLVED rating without
debate.)
Some users have NO respect.
To restore BIOS factory settings, simply remove the battery that is on your motherboard. additionally, here is your motherboard's manual: ftp://download.intel.com/support/motherboards/desktop/D845GVSR/SR_English.pdf
First you should make sure that everything is connected properly, Graphix card and PCI cards, DDR modules, processor and make sure the heatsink is properly installed on the processor, with fan turning.
Does the computer emit any beep(s) at start up? If so, go to http://www.customautomaticsystems.com/CAS/ShowArticle.aspx?ID=54
to find out what they mean.
After you try all this, let me know what happens.
Alex
Comment by nenalex2002, posted on Nov 11, 2007
Why would you rate a thanx for trying if I just told you the sure fire way to reset a BIOS? There is not much more than anybody can tell you with the information given.
You come here with a motherboard that is a few years old, ask a generic question which I answer, and instead of asking more questions, you just go with a poor rating. Thx!
You are the perfect example of why experts on this website are going to get tired of loosing their time with ungrateful people like you.
Alex
Rating Locked! (?) Sonyt has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Solution #8
posted on Apr 10, 2008
Guest
My system Processor is working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem.working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem.My system Configuration as mentioned below.
My PC gets Hanging frequently, despite of changing RAM, Processor Fan . It hangs during start up only and sometimes even in the BIOS itself. I cannot work on System more than 10 Min. Plz provide soultion
i have the same booting problem, sytem power will be on but not working properly display but display will be come the system workly properly. only on will be late and not come display very quickly...
My system has intel 845GVSR motherboard and it is not displaying anything, although all the other components like RAM,hard disk, processor are working fine.
I had reset the BIOS but it is still not working please help me.
