Question about LG 42PC1D 42 in. Plasma Television
Lg 42pc1d plasma tv red sparkles
This is a common problem having been on av forums website just wondered if you know anything that might help, basically red sparkles appear in any black area of tv, its worse when you first turn it on with a large area at top of screen completely covered with red sparkles. Someone mentioned it might be the sustain voltage that needs lowering, any help would be appreciated thankyou
  • raster Jun 11, 2008
    I began having the same problem with my LG about a month ago and it was getting progressively worse. The set is still under warranty. I quizzed the tech about the problem and got several evasive answers but in the end he let it slip that the cure may be a new set (at no cost to me). This is obviously a problem with LG and it is apparently becoming very common;
    maybe even epidemic..
I had the same problem, LG came out and it turned out to be the board that filters out the interference around the screen. I pretty sure that was it, took them 10 mins to fix by replacing a few of the boards inside the screen. Sorry I can't be more specific but its not an unfixable problem, so nothing to worry about.
Posted on Nov 26, 2007
My 42
H Malawi,
If the Unit is new kindly do not mess with it, ask the installation guy to help you out.
else check your AV input cables and connections taken from DTH or DVD player and check its resolution values.
If the TV is having a dead black display, call the LG repair center or customer care...
Regards:
Himanshu
Aug 28, 2012 | LG 42LC2D 42 in. LCD HDTV
I have a phillips 60pp9100D73 and there is a LOT of red in the picture. The blue is still fine but the red dominates the rest of the screen. When I hook up my HDMI cable with my PS3 it looks fine and...
Is this red sparkles? Or just overpowering red?
If It is sparkles you need to check the VS voltage in accordance to the chart on the panel. IF ok suspect the digital board is defective.
Feb 21, 2011 | Televison & Video
The ist light and second light shone red on my xbox but i cant find anything about these lights combo and a turned my xbox on and off and it worked what happend
You may have had a loose connection from the av cable ot your power supply may have over heated. The most common thing i see in my workshop is whn the AV cable csnnot be detected, all four will flash red, but in an over heating case, you will get flashing red on segments one and three. I hope this helps .
Apr 21, 2010 | Microsoft Xbox 360 Console
Lg plasma tv lost red color
The tv has lost VS supply to the Zsus board.
May 31, 2009 | LG 42PC3D 42 in. Plasma Television
Plasma screen
do you have the swich on the back of the xbox plug set up for reg tv? Does it work in that mode with just the red, yellow and white wire in the side AV slot? If you were using the xbox on another tv its possible you modified the display settings in the menu. Try hooking it up to a standard tv and reset the setting to default then try rehooking it up to the plazma.
Joe
May 20, 2009 | LG 42PC1D 42 in. Plasma Television
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
Static on 50
WHAT COLOR ARE THE SPARKLES? IF RED , BLUE AND GREEN, THEN IT NEEDS TO HAVE THE PANEL VOLTAGES ADJUSTED
Dec 08, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Xbox 360
if it is under warranty maybe you can ask the manufacturer if they can replace it or yuo can try to check this forum website also:
http://forums.xbox-scene.com/index.php?s=a80517f4a3a729e4ea6e710fc69b944f&showtopic=656926&pid=4316084&st=0&#entry4316084
Aug 22, 2008 | Microsoft Xbox 360 Console
LG 42PC1D 42 in. Plasma Television Logo
1,620 people viewed this question
Computer Repairing
Computer Repairing
