My Dometic ac unit is leaking water only during the day. What should I do?
Your drain pan is plugged up and allowing the water to rise above the edge of the pan and into the coach. The best way to repair this is to get on the roof and lay down next to the air conditioner. Look underneath the unit and you should see two white nipples sticking out the bottom about 1/3 of the way back from the front. These are the drain ports for the pan. Take a wire hanger or a long pick and work it into the hole of the nipple. The hole is kind of small and it would not hurt to open it up a bit. If you are unable to access the nipples in this manner, then the AC has to be removed and stood up so that the pan can be cleaned.
Hope this helps,
Jeff
P.S. The reason that it is only leaking during the day is because the evaporator creates more condensation in the hotter parts of the day than at night.
