Konica Minolta DiALTA CF910 Copier
Problem for Konica Minolta DiALTA CF910 Copier
Konica photocopier
By froggy 1 on Nov 11, 2007
I have just been given a konica 1020 photocopier, but no instruction manual. when i switch it on F36 appears. what does this function mean?
Best Solution
posted on Nov 11, 2007
Helpful)
Soulvisitor
Rank: Guru
Rating: 88%, 2382 votes
Was this helpful?
Yes
No
Solution #2
posted on Jan 07, 2008
Not Rated)
Nitrotrike
Rank: Guru
Rating: 88%, 844 votes
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Was this helpful?
Yes
No
Popular Solutions for Konica Minolta DiALTA CF910
Questions and Unsolved Problems for Konica Minolta DiALTA CF910
Do you recommend Konica Minolta DiALTA CF910 Copier?
Answer
Answer
how to change catridge in printer
Answer
I have a copier that needs servicing. It is an old Xerox XC1040 model and it needs a new drum or... (More)
Answer
msr206 not working perperly
Answer
wont print, was printing with this display for awhile, then after a paper jam, stopped working. have... (More)
Describe your Copiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in Sedona, AZ
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
