By it being diesel engine.it has a electric transfer pump low pressure pump.check fuse and relay.
If you're car has been running fine, then suddenly won't start, the cause is frequently that the fuel pump cutoff has been tripped. Open your trunk, and look for a label for a fuel pump cutoff switch. Locate the switch, press it in, and see if the engine will start.
where in the trunk is this shut off switch found?
