Question about GE Spacemaker JVM1640SJ Microwave Oven
Mouse I need drivers for mouse H097769
Http://rapidshare.com/files/203770778/97769.zip.html
Posted on Feb 28, 2009
  • GE Master
  • 9,098 Answers
You can get it here:
http://members.driverguide.com/driver/detail.php?driverid=580045
But you do have to register with that site.
Posted on Nov 18, 2007
My jvm149osh01 is making noise even when not in use
does this unit have a turntable and its ti turning?? Bad door switches??!!
Jul 27, 2017 | Microwave Ovens
Need amanual for a whirpool micowave model #mh1160xsql
Here is a direct link to the Owner's Manual for your Whirlpool microwave oven:
https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10170436A.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 30, 2011 | Whirlpool Microwave Ovens
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
How do set a mouse trap - i torn directions off am scare to experiment
Rule number one, BAIT IT FIRST!
Rule number two, always keep your fingers out of the line of fire.
When you are looking at the trap, it is sprung. That is, the mechanism is tripped, and the spring has flipped the bar to the "catch" position. You'll see the bar and spring. Look, and you will see another, single bar, connected on one end to the trap, with the other end loose. This is the trigger release bar. If you look at the bait tray, you'll see a place where the metal is pushed out on the side. This is the trigger. Here's how it works: You fold the spring bar over the bait pan, and hold it tight against the base, keeping your fingers out of the way (see rules 1& 2 above). While holding the spring bar down, use your other hand to bring the trigger release bar over the spring bar and to the bait tray. The end of the bar rests under the notch on the bait tray. As you are setting the bar, you'll slightly reduce your pressure on the spring bar. This pushes the release bar tighter against the notch. When the bar is in place in the notch, the trap is armed. When the mouse is tugging at the bait, the bait pan will shift and release the trigger release bar. It flips backwards, releasing the spring bar, which then catches the mouse.
Best regards, --W/D--
Jun 02, 2011 | Microwave Ovens
Our cat has chewed the power wire on our Zojirushi bread maker and needs to be replaced. Is there a local business in Ottawa area that can fix this for us?
Here are a few that were listed online:
http://www.abcapplianceservice.ca/
http://www.weblocal.ca/billys-appliances-ottawa-on.html
http://www.yellowpages.ca/search/si/1/Appliances+Repair+%2526+Service/Ottawa,+ON
Just use your mouse to click on the links, which are the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
However any decent electrician will be able to replace the power cord for you for a reasonable fee.
Good luck.
May 13, 2011 | Microwave Ovens
Screen goes black
It's a power save function. You can adjust it. If it's a pc go to "contol panel". There will be help there.
Mar 27, 2010 | Danby DMW119 Microwave Oven
The fan on our Kenmore microwave oven is not working.
My husband took the unit off the wall looked down into the fan and found a dead mouse keeping the fan from spinning. We removed the dead mouse cleaned up the area. Turned on the oven. The fan worked perfectly. Then he rehung the microwave.
Thanks!
Aug 18, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
MOUSEPAD DOESNT WORK! HELP HELP HELP!
Try here.
They have very good support links.
Jun 14, 2009 | Emerson MW8108P Microwave Oven
Mouse in vent fan?
Yes, the mouse was probably attracted to the warmth and food odors in the duct work and may have gotten trapped in the vanes of the fan and died. I'd act fast...
The best bet is to remove the oven from the wall, or almost from the wall, so you can see the area of the hood vent exhaust fan.
This is safer with two people and the installation instructions will be of great help.
You can download GE owner's manuals and installation instructions here.
Dec 09, 2008 | GE Advantium 120 Convection/Microwave Oven
I have a Panasonic NN-E273S microwave, it appears to work correctly but there is no heat, please help
If it is running, including plate rotating, and there is no heat, then you need to replace a part called magnetron.
The magnetron is located behind a protective plate on the internal side of the owen.
Here you see a general diagram, and you can also buy the part. Browse with the mouse on top of the picture to see the magnetron.
Here you can also get parts and diagrams.
If you want to call atechnician you can use the number listed on the owner manual.
Oct 11, 2008 | Panasonic Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
139 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
