Question about Sylvania SST4322 32" TV
TV turns itself off after a few seconds, no picture at all
When I press the power button, I hear the TV turn on. What I here is like a relay click, no sound or picture from the TV itself. It will shut off after maybe 5 seconds then turn itself on again. It will do this repeatedly, never do get a picture or sound. Also don't get the sound of the CRT powering up, if you know what I mean. Same problem. I have a Sylvania SST4243. It worked fine last night, turned it off for the night and it started doing this when I turned on today. Can this be fixed? Cost???????? Thanks.
  • 36 Answers
Re: TV turns itself off after a few seconds, no picture...
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Posted on Jan 09, 2008
  • 4 Answers
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Posted on Sep 10, 2011
0 characters
3 Points
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
I have an RCA television. After watching it on Friday, and turning it off. When I went to turn it on Saturday I had no sound or picture. The on/off button lights up when pressed. You can hear the TV click...
If tv is a few years old could be power supply capacitors faulty, sometimes the tv could come on after a while , had this problem on friends tv, Only cure would be replace capacitors, not a job for novice though.
Nov 08, 2010 | RCA Standard (CRT) Televisions
Green power light on but no sound or picture.
When I press the power button it just clicks.... what. ... vs-60603 I will only stay on for a few seconds and then shuts off. ...
Mar 30, 2009 | Mitsubishi VS-45502 45" TV
No picture, but power light is on
Mar 13, 2008 | RCA 27F530T 27" TV
Flashing Standby/Stero light and No picture.
How good is your picture when it did come ? Is it as good as it once was ? Or is it alittle washed out. If it is washed out the picture tube is weak . Sometimes turning up the screen control alittle would solve problem but if you turn it up too much you would have faint white line running diagonally. Now if you think the picture was good before you this problem video circuit would be your suspect . Jungle IC or something in the RGB circuits . Good luck
Feb 27, 2008 | Sony KV-35V35 TV
KV 27S65 Sony Trinitron 27"
So far you have done all you can and you have done everything right. The fact that the TV turned off by itself and then turned back on by itself suggests that one or more solder joints have come loose inside the set. A qualified tech should find this easy to fix, and Sony sets are always worth repairing, so it is now time to have the set serviced by a tech experienced in Sony standard sets.
Sep 01, 2007 | Sony KV-36XBR400 36" TV
Picture tube doesn't turn off
The power relay driver or the relay itself is bad. Its sticking closed so the voltage is there for the power supply but the micro has turned off the tuner.
Sep 15, 2006 | Panasonic CT-27G23 27" TV
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
Sylvania SST4322 32" TV Logo
2,947 people viewed this question
Top Sylvania Standard (CRT) Televisions Experts
Kenneth Walker
Are you a Sylvania Standard (CRT) Television Expert? Answer questions, earn points and help others
