The red tint goes in and out. When you first turn on the set the red tint is normally out. After the...
(More)
The red tint goes in and out. When you first turn on the set the red tint is normally out. After the set warms up for ten to fifteen minutes you can pick up the lower right front corner of the set a couple of inches and drop it (sometimes it takes 2 or 3 drops) and the tint comes back in and the picture is fine (for hours) until you turn it off. You can turn it back on immediately and the red tint is gone again. What do you think is the most likely cause of this problem? Thank you.
I have a 1994 Toshiba Television. It was working perfectly until I moved it. I can't get the...
(More)
I have a 1994 Toshiba Television. It was working perfectly until I moved it. I can't get the volume on. PLEASE help. I've tried everything, I think. Joyce S.Model # CF32C50.
Toshiba 27AF43 CRT (2002) won't come on after power outage. It was plugged into a power strip and...
(More)
Toshiba 27AF43 CRT (2002) won't come on after power outage. It was plugged into a power strip and was off at the time of outage. Now, nothing happens when power button pushed. Is there a reset?
