Question about Palm Treo 680 Smartphone
No back light.
Keyboard light is on but no screen back light...ever. I have reset it in all ways several times
  • 5 more comments
  • lachosv Mar 05, 2008
    i have problems with my palm treo 680 the light on the keyboard works but the light of the screen doesn't what can i do for see the light on the screen
  • drfunkmaster Mar 13, 2008
    my keyboard works the phone works as normal, but i need to shine a flashlight on the screen to be able to read anything. How do i fix this problem.
    any responses are appreciated.
    Email me.
  • acaldarone69 Jul 02, 2008
    I'm having the same problem and I don't know how to fix it
  • rposeyzoe Jul 06, 2008
    My back light has deemed and even goes out in the middle of me using text. What is the deal? Is there a cheap answer?
  • MariposaPoca Aug 06, 2008
    this is totally weird that so many of us have the same problem. (i.e., me too!) So has anyone called Palm and asked them whaz up?
  • fjrivas24 Aug 15, 2008
    I have the same problem. Apparently my wife accidentally spilled some coke over the phone and the keyboard was all sticky, other than that it was working fine. I decided to open the phone to clean the keyboard and when I re assembled it the phone was working fine but the screen backlight was not working. The keyboard backlight is working fine but not the screen backlight. I have hard reset and sync the device many time since but with no luck. If you have any suggestions pls let me know
  • jossyjoboy Oct 28, 2008
    I had left my phone at a friend's place and when it was returned the screen light was gone. whenever i try and press the reb button, the light just blinks for a fraction of a second. It has got nothing to do with adjusting the brightnes. May be somethings gone wrong with the settings
The option + p only adjusts the keyboard brightness.
Posted on Jul 15, 2010
Try pushing option + P  it will adjust the brightness on your screen. dont know if itss waork but it worth a try:)
Posted on Dec 19, 2007
Blank screen, no signal to monitor, no HD light, no mouse light, no keyboard lights, no beep.
maybe it could be a frayed/broken wire leading to the visual/sound parts. if not then bring it to tech support and have them look at it
Dec 20, 2013 | Computers & Internet
Cant access BIOS to reset it
turn the unit off completely
then turn it on as normal and press the delete button ( hold down) to activate the bios screen
go to the boot tab and enter on it ( keyboard will not click on but the arrows will work)
you will see a list of boot options in a drop down box
make usb no one , enter then esc
you can at the same time arrange the booting sequence as 1,2,3,4 etc
Apr 05, 2017 | Computers & Internet
No power timer light keeps blinking did the reset also unplugged stil no power light keeps blinking plz help thx
Only two possible reasons for this.
The green blinking light is the DM unit in the set trying to boot up and failing. There are several caps in the DM unit that puff up and can cause this problem (1000 mfd at 16 volts).
There is something else you should try first, it takes less than ten minutes and requires only a screwdriver.
Pull the front speaker grill off--it is held in with plastic pegs.
Remove the inspection plate dead center behind it--several philips screws.
Locate the two sets of wires coming from the keyboard on the front of the set and follow them down and to the right--you will find two plugs that can be disconnected-----the idea is to take the front keyboard out of the circuit.
With the keyboard unplugged you can still attempt to turn the set on with the remote--the receiver is located behind the screen.
If set now works you have two choices--operate it with the keyboard disabled or remove the entire screen assembly to get at the front keyboard---you can unsolder the reset button and remove or replace it. This is so common I carry replacement reset switches when I do service calls===it is a tiny switch.
If the set still does not function the DM unit (it is a large metal box located on the left side as you look from the back) is defective.
It is no longer available from Mitsubishi but can be removed and sent out to someone like PTS Electronics for repair--you can email them in this situation and get a quote for this.
If taking the reset/keyboard out allows the set to work I would use it that way.
If this information told you something you did not know rate this solution as "very helpful" as I do this here for free.
Let me know if you have questions.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Rapid flashing green light but no power. I've reset - no effect, unplugged set for a couple hours and several days - nothing. Continual rapid flashing green light when plugged in. Also, when I plug the set...
1.) Most of these sets have a receiver built into the back(large metal box on left side as you look from the back.)
2.) Two possible reasons for green light constantly blinking(it is the receiver booting up if the set is disconnected from power---light should blink for about 70 seconds and go out).
3.) First reason: The recessed micro switch on the keyboard marked reset may be bad--does not happen a lot but it does happen. Easy way to see if this is the problem is to remove front speaker grill---and inspection plate behind it---from the keyboard you should see one or two groups of wires(they come from the keyboard) follow them to the right and unplug both(they are different and marked with letters). This takes the keyboard out of the circuit---you should still be able to turn the set on with your remote(remote receiver is behind the screen.) IF SET NOW WORKS YOU HAVE TWO CHOICES--USE IT ONLY WITH THE REMOTE OR HAVE SOMEONE REMOVE THE FRONT KEYBOARD AND UNSOLDER THE RESET SWITCH--the switch can be replaced without replacing the keyboard(it is a small circuit board with all the micro switches on it.)
4.) If disconnecting the keyboard does not fix the trouble---you have a problem in the "Receiver"----it happens on these sets and usually is repairable--Mitsubishi no longer sells this part and it was very expensive when they did---if disconnecting the keyboard does not cure the problem---let me know and I can give you options for getting the receiver repaired.
5.) Let me know if you have questions and if you need more advice reply to this post here.
I do this here for free so if this information helps you take a minute to give me a vote here---I am here to help people.
REGARDS, SD TECH
Sep 16, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Black screen on startup
I have had this same problem with a HP DV2000 and the problem is not the contrast light. What it is, is that the laptop thinks that the screen is been shut down that is why the light does not come on. The best way to solve this is to remove your keyboard first.
You can remove the keyboard by removing exactly 7 screws from your laptop back, there are 5 screws located under your battery and other two that are in the location of your RAM'S.
Just open them up and then you will notice that the key board pops out abit then just simply take it up and then just below the keyboard, on the same line where HP brand logo is on your machine there are two small clip types of pind, that you can remove and put back.
There is a clip that is hidden abit under the metal plate, so just try and remove that clip from its place using a needle or any long and thin object.
That will make the laptop not have the problem. But once you remove that the laptop constantly will think that the screen is open even if you close it. then after like a week or two you can put it back and all shall be fine if not then just remove it and keep it out.
You can then set your power options to shut down the screen light every 2 minutes or something like that so as to avoid the backlight being switched on all the time.
Hope this solves your problem.
May 27, 2009 | HP Computers & Internet
Mouse is recognised but key board is not.
Normal 0 Press the Receiver button (and the lights will start flashing.
Turn the Keyboard over and press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver. Should work okay then.
Hope this helps. Bud
Feb 18, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Microsoft wireless keyboard 6000 v 2.0 often stops working. No idea what the lights on the little wireless hub means as no instructions. Help files do not mention anything either. I have erases=d drivers...
Are your batteries in the Keyboard and mouse good?
On the receiver there is three lights. The "A" is the CAP LOCK light, The "1" is the RECEIVER light and the "F" is the F LOCK light.
You probably have gotten it working by now but here is a way to get it work if not.
Press the Receiver button a(and the lights will start flashing, then if its the Keyboard that isn't working, press the small RESET/CONNECT button on the back of the board to connect.
If its the MOUSE do the same except push the small RESET?CONNECT button on the back of the mouse to connect. Then they should work properly. Hope this helps. Bud
Nov 15, 2008 | Microsoft Wireless Laser Mouse 6000 v2.0
Logitech wireless mouse and keyboard
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Sep 23, 2008 | Logitech Cordless Mouse
Keyboard doesn't work
Sep 13, 2006 | Gateway 2520915 Keyboard
Palm Treo 680 Smartphone Logo
304 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
