Question about Technics Audio Players & Recorders
Technics SA GX710 having sound problem pls help
Technics sa gx710 when switched on it works fine for few seconds only after that graphics disply for equalizer not showing i mean only shows frequency numers but actual frequency display not showing and also no output from one of the speakers some times no o/p from front right or sometimes no o/p from front right i tried resoldering loose connection but still unable to solve the problem when swithed to FM it displays tuned indicator but imbalance output from left and right
  • soundlessks Mar 08, 2008
    I have an SA-EX400 with no sound and no LED read-out. Sound worked fine until I plugged in some headphone. Now I get sound from the headphones but not through speakers
  • 979 Answers
The system has detected a fault in the output section. How much are you asking of the system? Greater than 50%? That will push most systems to their limit in a short period of time...accordianman
Posted on Jan 14, 2008
  • 682 Answers
SOURCE: Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Posted on Aug 06, 2008
SOURCE: Technics sa-g78 no sound from front speakers
Buy yourself a nice Krell amp!!
Posted on Jun 25, 2009
SOURCE: Technics SA DA20
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
Posted on Jul 13, 2009
  • 95 Answers
SOURCE: Overload on Technics SA-AX710 Receiver
Turn it off...remove all the speakers and turn it on....If it goes into the protect mode. you have a bad power amp. That's the big black flat things attached to the cooling fins.. one or both is shutting the system down. If it doesn't trip out, plug a head set into the phono jack and see if you can hear the music there. Can you turn it up without tripping.... if it's still ok...hang one speaker on the system, if it trips thats the bad leg...check the speaker/wire
Posted on Oct 23, 2009
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
Bios password reset
Locate the coin cell battery. Remove it. Wait 10 minutes. Re install battery and reboot.
Apr 27, 2014 | MSI GX710-Titanium (GX710-250) PC Notebook
Technics SA-AX530 all modes not working - no sound
Not a good sign. There should be a click a few seconds after you turn on the unit. That says the output section is OK. If there is no click, you need repair. Perhaps only some fuses inside, but it could be worse.
Also make sure that the speaker switch is in the right position, like A, not A+B. Also the headphone jack can silence the speaker.
Make sure that ALL switches are in the right position.
Dec 17, 2013 | Technics SA-AX530 Receiver
Digital input glitch, switches randomly from analog to digital.
what connections do you use for the device you are listening to, and what device are you listening to when this happens. you should use either an analog, or a digital connection to a device, but not both
Mar 08, 2013 | Technics SA-DX930 Receiver
Technics sa-gx670 reciever sound drop
it could be that your amp chips are gettin hot
Jul 22, 2010 | Technics SA-DX750 Receiver
We have just installed a Bose lifestyle system, with SA 2 and SA 3 amplifyer, with a second set of speakers in another room. we cannot get sound to the second room. the second remote is not responding....
Make sure you unplug your sa 2 and sa3 amplifiers after setting the codes. Wait at least 60 seconds, then plug back in. I would also unplug the in and out boselink cables as well. Once youve waited for a minute, then plug everything back in. Should work. If not, call Bose technical support. They are really great. I have 15 SA 3 amplifiers throughout my home. They are great.
Mar 21, 2010 | Bose Lifestyle SA-2 2-Channel Amplifier
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
May 23, 2009 | Technics SA-EX400 Receiver
Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Feb 18, 2009 | Technics SA-DX950 Receiver
Technics SA-DX950
when turn on receiver , after few seconds got message
F70. when wants to do any operation with receiver got message SWITCH POWER OFF
Jun 25, 2007 | Technics SA-DX950 Receiver
380 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
