GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side Refrigerator
Problem for GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side...
Water collecting on bottom of 13 year old fridge
By rotstein1 on Jul 05, 2009
I don't know if it's on the right setting. It has a picture of a fridge with a no drip sign. I don't know if this is relevant. Never had this problem before.
Solution #1
posted on Jul 05, 2009
Somewhat Helpful)
coldwells
Rank: Apprentice
Rating: 75%, 1 votes
All refrigerators create water when their cooling coils shed frost build-up - that water typically collects in a tray under the fridge body through a drainage tube that exits from a collection trough inside the fridge under the coil through the back of the fridge housing.
First check the tray to be sure it is not accumulating food particles which ultimately can produce molds. Clean any water from that tray first, then look for the tube exiting on the back of the fridge see whether there is any moisture at the end of the tube under the fridge and notice whether the tray has had any recent moisture. Chances are the tube is either plugged or similarly any connector through the fridge wall.
Now, be CAREFUL not to puncture the hose or the connector with a sharp instrument however the drain path must be cleared. Try blowing through the drain inside the fridge with a straw, then add a small amount of baking soda into the collection trough, adding a small amount of water to dissolve and allow this to gradually drain out normally. Only detach the outside tube if the problem has not been resolved in this manner. The tube can be replaced easy enough, the connector through the back is another question - see you parts dealer if it has been compromised.
Was this helpful?
Yes
No
Popular Solutions for GE GSS22JEPCC / GSS22JEPWW /
Questions and Unsolved Problems for GE GSS22JEPCC / GSS22JEPWW /
Do you recommend GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side Refrigerator?
Answer
Answer
Where is the fan located at on this appliance? I am a single mom and don't want a repair expense... (More)
Answer
i have a general electric side by side model gss22jepaww, it will not dispence water,ice maker... (More)
Answer
Hello, I have a GSS22JEPCC. It is 3 years old. The refrigerator is not cooling and freezer is not... (More)
Answer
The red light on my water dispenser went off along with the beeping alert. I got a new water filter... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Tulsa, OK
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
