Sounds like you have a wire that is ALMOST broken or the insulation is worn off and grounding, or turning is pulling a wire loose from a connection. .. this type of problem is HARD to trace down sometimes... good luck
did you adjust the valves? check and make sure the fuel pump is putting out enough fuel, way past time to replace it. check your voltage too, the regulators in those are famous for dieing.
If you have no power to your starter, it will not start. Check the positive battery cable going to the starter and make sure it is tight and not burned.
