Question about Disney Mix Max Digital Media Player
Disney mix match will not keep a charge
It is charged like the manual says and will say battery charged but when I unplug it it still shows low battery in the red.
Re: disney mix match will not keep a charge
Oh ya, the company told me to send it back if it was over 90 days and to send 35.00. That is no good, the unit cost me about 70.00. So I need to send half the cost to fix a problem which I feel should not be happening. I hav two of them and charged them the same but only one has the problem.
Posted on Mar 13, 2008
IF it has been less than a year the company will take the unit back test it and replace it if need be. That's what I just did. They say I will have a replacement back in 2 weeks.
With the player, it is recommended that you only charge the player for 3.5 hours, no more cause you could ruin the lithium battery that is in it. It could be possible that you overcharged the unit if you went over 3.5 hours and if this is the case then it will not hold a charge.
Posted on Mar 12, 2008
Get an apple ipod.
Posted on Nov 13, 2007
0 characters
3 Points
Disney MixMax player... JUST bought this device. I installed the software CD, but that is JUST for the online/media storage component... I plugged it into the computer & computer wont recognize it at...
The manual indicates that it should show charging as soon as connected, and takes three hours to charge.
I have found that on some devices, this does not happen, and it takes a few minutes for the device to get enough charge into the battery to start up. This especially from new, or if left for a long while.
Try giving it a long charge, six hours is recommended by some manufacturers, using the same type of battery.
leave your computer on, it won't hurt it, as the USB ports, only supply power when it's on.
If it does not work then, as you have only just bought it, take it back.
Feb 07, 2011 | Disney Mix Max Plus DS19025 Digital Media...
Mix max wont turn on even though its chargeing.
if u just put it in and it says its ok to remove don`t remove it kep it in for like 5 min. then take it off the charger
Jul 24, 2009 | Disney Mix Max Digital Media Player
I lost my disney mix max charger
There are several types of chargers you can use with the mix charger, wall charger, USB to computer (FYI turn your computer off while charging and it stops), and my favorite - the speaker station. Just do a search for disney mix max charger on the internet, amazon, or ebay and several options will come up. I like the speaker station because it is easy to charge with it and lets my daughter use it as a stereo and dance unit if she wants.
Dec 10, 2008 | Disney Mix Max Digital Media Player
Turning on the disney mix stick
Put the power switch into the down position so that it's showing a green color and press the Play button. If that doesn't work you may need to charge it.
Jul 22, 2008 | Disney DDA8040 MP3 Player
Mix Max
Try pressing the reset button on the bottom of the player with a tack or paper clip. If you have a SD card try removing it and then reset the player.
May 31, 2008 | Disney Mix Max Digital Media Player
Try going to the following link and follow the directions to flash the firmware in your player. If that doesn't work I'd suggest you call their support line to see about setting up a warranty replacement since they have a 1 year warranty on all of their products. Keep in mind you'll need to have your receipt for verification of the original purchase date and warranty period.
May 13, 2008 | Disney Mix Max Digital Media Player
Charging the Player
The player needs to be charged before it can be used and every time
the battery gets low. It takes approximately 2.5 hours to charge the
Player. Once fully charged, the Player lasts approximately 8 hours.
To charge the Player:
Remove the USB cover on the Player.
Connect the Player to the PC using the Flash Plug.
The Player will begin charging. The battery indicator should begin
to flash, alternating red and green.
Once the battery is fully charged, the indicator light will stay red.
Note: If this is the first time the Player is connected, wait until
Windows detects the Player and follow the prompts to install it.
Mar 15, 2008 | Disney Tink Digital Mix Stick MP3 Player...
Wont charge
there seems to be no solution to this. I have the problem to and the 1.888.800.0502 phone number is no help. If you have your receipt- TAKE IT BACK AND GET AN IPOD! That is really the answere.
Feb 15, 2008 | Disney Mix Max Digital Media Player
Disney mix max mp3 player
I suggest you just wait for it mine can take minutes to start up but it still turns on so wait a few minutes if not working get someone to look at it
Dec 29, 2007 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
266 people viewed this question
Top Disney MP3 & Digital Media Players Experts
Sudeep Chatterjee
Sudeep Chatterjee
mac colar
Are you a Disney MP3 and Digital Media Player Expert? Answer questions, earn points and help others
