SOURCE: iphone frozen on white blank screen
Hmm. I've been browsing the net for iphone problems (courtesy of my own) and i remember reading something about this. Look up the Apple website, especially the discussion forums. You might find something there.
In the meantime, try restarting your phone. For that, press both the top on/off button and the Home button together and keep holding them down. Your screen will go blank but keep holding them and the phone will restart.
If this doens't fix things, look up other answers. You might have to restore your phone, like I had to, You should be able to find the procedure to restore easily on the Apple website.
SOURCE: iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
SOURCE: My iphone got stucked on the apple logo
here is a small tutorial that my help you....good luck I hope this helps please don't forget to rate
http://www.youtube.com/watch?v=u4xLvpazV24
SOURCE: iphone touch screen problem
Try pushing the power button and the home button at once and wait for it to restart, that should fixed the problem...
SOURCE: Screen Alignment Not working on SAMSUNG OMNIA
sometime it takes few attempts (once I had to do it 9 times !).
