Question about Foxconn 661M03-G-6EL Motherboard
Tv has no sound
Rca 27 inch flat screen. Bought in june06
  • 263 Answers
Re: tv has no sound
First you have to make sure there is sound coming out the tv can you use hearphones and test if there is sound if there is may be your speakers are no good any more
Posted on Dec 31, 2007
0 characters
3 Points
Trying to get sound on the tv but dont know how as the sound is only coming from the laptop.
Check and see if your laptop has HDMI hookup if so you can use that if your TV has HDMI as well if neither has and it only has VGA it it may not be able to get the sound and the only way to fix that is to get an adapter that converts the head phone connector 3.5 mm more than likely to what ever input your tv has for sound like rca then connect the wire from the laptop headphone output on the front into the tv input to get the sound.
Aug 22, 2011 | Motherboards
How do i connect my nintendo to my samsung led tv
I am assuming that you are talking about a Nintendo Wii.  When you buy a Wii it comes with standard RCA composite cables that are three colors, Red, White and Yellow.  Yellow is the cable that carries the video signal and the red/white carry the stereo audio signal.  You would need to connect these cables into the corresponding color inputs on your tv.  Plug the yellow ended cable into the yellow jack on your TV and do the same for the red and white cables.  After this is done, you will need to switch your tv's input to the input that corresponds to the one you plugged those cables into.   Some newer flat panel TVs do not come with RCA composite inputs.  If this is your problem, you will need to get some component cables for your Wii.  These cables look identical to RCA (composite) cables but come in colors red, green, blue, red and white.  In this case the red, green and blue cables carry the video signal and the red and white carry the audio.  You can purchase these from just about any store that carries the Wii or online from places such as
You would hook these up the same way by matching the colors and then changing your tv to the corresponding input.
Hope that helps!
Jun 27, 2011 | Motherboards
Hello I would like to know if and how i can hook up my computer to watch dvds and or downloaded movies on my tv screen. as my laptop screen is smalI. I have spoken to people at electronic stores but they...
You don't really need the VGA part, but something like this would fix your problem.
What you're looking for is an HDMI to RCA adapter. The electronics store should know what to look for.
Good Luck,
Apr 22, 2011 | Motherboards
You don't need any drivers for this. The Olevia TV has a native resolution of 1280x768 i think for displaying signal from cable. That is enough for a tv, it's not made to be a computer monitor. You will have to deal with it or buy a Computer monitor that can be used as a TV.
Mar 06, 2011 | Motherboards
Screen was working fine until my daughter opened it up all the way flat to the back. Now it is just black all the time. If I shine a light close up to the screen, I can see what is on the screen and...
It is a backlight problem, it most likely was broken when the screen was opened flat...
Check on Ebay for a replacement screen, Average price about $125.00 for a 17 inch screen
Feb 11, 2011 | Motherboards
Hello, I was wondering, if there is any way to connect my computer, which is a Dell Dimension C521, up to my T.V., which is a 32 inch ilo. I have a Philips Video and Audio red white and yellow connector,...
Connecting a pc to a TV is quite simple. Your PC has either a vga out or HDMI port. Just get the right cable and connect to your vga port on the TV or HDMI port on your TV.
This way you can even have the two screens running, alternatively press Fn and the appropriate F key to switch off the laptop screen.
Your sound will still be thru your PC speakers.
Jan 10, 2011 | Motherboards
The volume of the cube is 270 cubic inches. How many square inches are there in the surface area of the cube?
Are you sure you didn't mean 27 cubic inches?
That works so cleanly to a 3" square and an answer of 54
270 gives a repeating 6.whatever. That's as close as you get in the freebies for what is likely a typo
Nov 24, 2010 | Motherboards
I purchased a Philips 32 inch television Serial number DS1A1025102340 Model number 32PFL4505D F7 last week. Please tell me how I can connect ear phones. How can I connect additional speakers (the current...
Unfortunately I can't locate any connector for your headphones at the official manual. You can use the connection for Digital home theater amplifier, described at page 31 from this manual, in order to connect your TV with the Digital home theater amplifier and use the headphones and the FM Stereo Transmitter that you want, connecting them at the amplifier. In case you don't have a digital home theater amplifier but an analog one you can use the analog output jacks marked as #8 on page 28 at the same manual (using an pair of RCA to RCA cable). In case of further details needed, post me back the way you're going to connect the devices or your amlifier's brand / model to give you the details you are looking for.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
direct fixya link:
Nov 10, 2010 | Motherboards
I have connected my macbook to the tv via VGA cable...i have the picture displayed, but the sound is still only coming out of the macbook speakers. How do i get the sound to come from the tv??
Connect the sound output (head phnone or line) of the laptop to the component input for sound on the TV. You will need an 1/8" plug to sterio RCA adapter to connect.
Oct 02, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Black two inch line down screen
The monitor is bad. The two inch line down the screen is dead pixels. This is a comon problem on both laptops and flat panel monitors. It will need to be replaced. If it is still under warranty, it will be covered.
Dec 19, 2008 | Toshiba (K000823110) Motherboard
Foxconn 661M03-G-6EL Motherboard Logo
20 people viewed this question
Top Foxconn Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Gareth Cockram
Gareth Cockram
Are you a Foxconn Motherboard Expert? Answer questions, earn points and help others
