I have a Thetford electra magic toilet it will not operate when to flush button is pushed. I have it hooked up to a 12 volt battery as instructed. The person I bought it from said it worked for brief moment when he checked it. What could the problem be?
Instead of calling thetford, get ahold of the tech guys at the www.thetfordguy.com ,email: [email protected] eThetford RV Toilet Parts and Products for Sale
The guy new what he was talking about, had even fixed them himself.
Does it have water . spray the button with wd40
SOURCE: how do we empty and maintain our thetford porta
Go to www.thetford.com.
Click Customer Support then Product manuals and download manual in PDF format.
SOURCE: Hi, have a built in thetford toilet in my caravan.
Don't send money. Just go to thetford.com and download info.
Some tips - if seal is old and breaking up make sure you recover all the bits which have fallen into the flush water tank. If new o-ring seal not available use outdoor silicone sealant and allow to set for 48 hours before adding anything other than a small amount of water to test flush action. Electric circuit includes a fuse and microswitch which are both contained within the flush water tank but you are unlikely to have problems with these items.
SOURCE: We have a thetford C200cs on the motorhome we have
Red light is just a reed switch that turns on the LED when a floating magnet inside the cassette floats up (when the cassette is full) and switches on the reed switch thereby switching on the LED. It just tells you the cassette is full and you need to empty it.
I'd say either your button or electric valve is broken. All the button does is allow the electric valve to break the seal that allows water to flow from your onboard water system.
I'll assume that the water in the rest of your motorhome is working?
So check the switch first.
You can lever off the switch/LED panel and remove the square connector from the back of the button. Get a multimeter and set it to either Continuity or Resistance (Ohms). Place the connectors on 2 of the switch pins and press the switch (the switch is actually 2 switches with 4 pins, but each pair of pins is connected together) - if you get a beep (if multimeter on continuity) or low resistance reading (if on resistance) then the switch is working - if this is the case then it's probably the electric valve. If the switch is not working, then that's your culprit.
When you replace the connecter you can replace it either way round.
SOURCE: hi our thetford cassette toilet (c200)blows the
Probably the rotor has come to a stand still (carbonade). I suggest you will clean the rotor with an house-hold acid liquid (like the one for cleaning coffeemachines).
Flying Dutchman.
SOURCE: toilet will not flush when
when we push the blue flush button no water comes out can you help
