SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
SOURCE: bar chain oil leaking into case when not in use
if you store it somewhere other than a climate controlled building , the changes in temperature can cause the oil to expand out of the saw a little each time the temp. goes up.
try some absorbent cloth
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
SOURCE: not much oil on poulan chain saw bar
there is some debris blocking from entering the bar and when sits it seeps out,clean bar and are under chain cover
SOURCE: bar oil leaks when saw not in use
What you describe is common in many chainsaws. Try loosening then reseating the oil cap before putting her away to relieve any pressure built up in the oil tank. Check all the hose connections.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number of you saw; uncheck "Manuals"; Check “Illustrated parts lists ”; then search.
Serial number breakdown: 06 1500198 (Husqvarna 359)
06 = year produced (prior to 2000 there is no space and only the first digit is used (61500198 could be 86 or 96))
15 = week in 2006 it was produced (March)
00198 = 198th unit produced that week regardless of model or type
