FixYa.com
Tags:
Quantum Fireball 1.08 GB Hard Drive
Dead hdd
posted by Fergi on Nov 11, 2007
I have a Quantum fireball HDD. Not sure of the capacity (I have had it for a while but not used it for so long). Anyhow, I need to recover some data from it and it seems not to work. When power is applied the drive spins and the light on the main board flashes but it soon stops spinning and cannot be accessed. The LED flashes seven times folowed by two times and then repeats.
Can you tell me what to do to recover the data. Don't really care about the drive
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 11, 2007
FixYa! (100)
night71
Rank:Guru Guru
Rating: 90%, 496 votes
I am assuming that you have a Windows platform. Take the hard drive out out and try it on a Mac. Sometimes a Mac will pick up faster than Windows. I would try that first for sure. Finding a Mac computer is not hard if you have a computer retail store near bye. Some smaller outfits may test it for you for free and hook it up to a Mac. If my solution sounds off the wall: consider opening your hard drive knowing that any wrong tinkering can easily result in a totally useless drive. If you are ready to open it if a Mac doesn't work, go slow and don't bang it around. You can't get very far, but you could check for any loose wires and check the board with a tester when no power is attached. You should not try to open the area with the physical drives, any wrong move there will destroy any chance of recovery. If all seems to fail, then yes, give it a tap or so. The FBI will do it for a crazy cost that would make buying a car easy.Good luck
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Hard Drives problems?
Hard Drives
I/O error
Then it says Device [1:0:0]... Answer This...
Hard Drives
USB Plug and Play stopped...
My Beyond Micro 250GB Mobile... Answer This...
Hard Drives
necesito driver de sonido
sony vaio instal? windows vista... Answer This...
Hard Drives
drive not detected in Mac
I had used the Maxtor OneTouch... Answer This...
Hard Drives
My external hard Drive DIGITAL...
My computer doesn,t noticed it... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
