Question about Kenmore Refrigerators
Kenmore fridge stopped working
Hi, my fridge was just taken out of storage, it was in there for about 2 years. I plugged it it and it was working fine, cold, for about 3 hours but had a smell in it that I wanted out so I left the door open for about a half hour while the unit was running, which sounded like a good idea at the time, not anymore!! When I went back outside it was completely dead, fan not running, nothing. I tried the plug, the reset button, nothing worked. Did I kill my fridge? The manual said if it stops running to check the fuse but it does not tell you where the fuse is located. it is a kenmore- model R134a please help. Thank you.
While not specific for your model number, this Kenmore manual has lots of information about changing fuses, checking wiring, etc.
Posted on Apr 12, 2017
  • 236 Answers
SOURCE: kenmore freezer and fridge is not cold - not frost build up - compress anf fans are all running
You need a qualified technician for this problem.
- Your unit may have leaking try to check for oil traces.
- The system maybe restricted, system reprocess is needed for this unit.
- If the unit is no frost try to check if there is an air circulation inside the unit. If no air is present then check your fan motor inside.
Posted on Jan 11, 2008
SOURCE: Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Posted on May 23, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
  • 150 Answers
SOURCE: refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
  • 28 Answers
SOURCE: Hi i have a hotpoint mistral plus fridge freezer,
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Posted on Jul 23, 2009
Kenmore Model No. 253.53322302 side-by-side not cold enough. Incidentally, fridge was unplugged in garage last 2 years until plugged in 2 months ago. Fridge stays at 38 F and Freezer at 27 F, so ice...
Since your fridge/freezer has been in storage the gas has settled, did the fridge/freezer get put on its side at any stage during the move?
This could have caused leakage out the breather pipe, have a look at the condenser at the back of the fridge, down low, you will see two hard pipes coming out of the tank, one leads up into the fridge the other doubles over, is open ended and facing downward, this is the breather and gas can escape from this pipe when the appliance is tilted to far over.
Chances are high that you will need to service this appliance.
its a good idea not to turn on immediately after moving. giving the gas time to settle again before turning on.
It could be the door seals need replacing as they can go hard over time when just sitting and no longer form a good seal on the door.
Feb 07, 2014 | Kenmore Refrigerators
106.56532400 this is the model number for my fridge I moved fridge from home to storage left it for 2 weeks brouhgt it back home let it sit for 2 days then plugged it in and did not freeze or get cold i...
sound like there is a leak at the tap he installed or in the evaporator. call him back and have him to repair it right. He should have checked for leaks.
Dec 17, 2010 | Kenmore Refrigerators
2 yeaor old kenmore fridge not working, motor runs
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Jul 12, 2010 | Kenmore Refrigerators
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
if u can hear the compressor going , then dont worry about fixing it , it would need to be regased , not worth it too old, if u cant hear the compressor going then it wud be a cheap fix wud need a new thermostat or a defrost timer
Jan 31, 2010 | Fisher and Paykel Fisher Paykel 21768 -...
with the unit being that old , the compressor probably whent out the oils inside probably froze up ,,,,, to replace a compressor you are better off replacing the unit it is a major repair
Jan 31, 2010 | Fisher Freezers
Kenmore coldspot
hi thanks for the question i would check the cold control what is happening is that the fridge gets cold enough but because of this bad control it wont send power to the rest of the fridge replace cold control thanks the appliance doc
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refridgerator 7 years old
If the fridge has a grille round the back that gives off the heat, that might be covered with fluff and spiders which will be reducing it's ability to dissipate the heat from the compressor. It might be worth having a look at that. Otherwise, it might keep going for 25 years like mine has :-)
Hope this helps, D.
Jul 16, 2008 | Kenmore 52642 / 52644 / 52649 Side by Side...
Ice maker hooked up for the first time doesn't work.
Hi, The storage is usually on the back fridge wall near bottom. Your answer indicates the demand solenoid is not operating. You will need to check wiring connection at the solenoid, and at the ice maker plug. Best of luck.
Apr 27, 2008 | Samsung RB215LASH
Fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Jan 16, 2008 | Kenmore Elite 21082
Refrigerators Logo
695 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
