If you remove the screws holding the handle pieces together you can separate them and remove the actuator and put the new one in the same place, then put the handle back together.
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
<p>Yes, the early version eSERIES on the <a href="http://www.rainvac.com/cap-cover-asm-120v-e">Cap Cover Assembly</a> was a disc that was glued into place. You can order the new design that is one complete piece so this problem will never happen again.</p> <p>RainVac </p> <p><a href="www.rainvac.com">www.rainvac.com</a></p> <p>800-523-0510</p>
You've probably sorted your problem already ... if not, try the following link: http://www.goodvac.com/Rainbow_e_series_vacuum_main_unit_parts_s/798.htm (they have everything, good prices and very reliable) ... Tip, if you order brushes, order Brush Seating Stones with it, they help cleaning the commutator and so eliminate poor contact and sparking.
the water basin has a safety on it so the unit cannot run without it. if you look on the bottom of the rainbow you can see a small oval shaped space that you can depress just to test and see if it still runs it will only run with this depressed.
You have to have the Aquamate II shampoo attachment in order to clean/shampoo your carpet. Go to the Rainbow website and you can purchase it if you don't already have one - if you do have one, this site also has simple directions on how to set up the Aquamate to shampoo your carpet.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=620181 Rainbow Aqua mate 2 (by 3 users) Posted by nicks mom on May 24, 2008 I cannot get water to come out of the water basin in order to shampoo. It is all connected correctlyXThis Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 2 Other Users Have the Same ProblemComment by deucedown, posted on May 26, 2008Same problem here, I have only used the shampooer twice and water will not come out of the basin. I need to shampoo my carpets today and this is very discouraging. Somebody please help. I hooked it up and followed the directions.Comment by Angela31, posted on May 26, 2008We are having the same problem. Everything is connected and no water is coming out. We have only used our Aqua mate 3 other times. Please help.Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum / Aqua Mate. It has been a long time since I have operated a Rainbow Aqua Mate so I suggest that The best solution to operate the Rainbow Aqua Mate is to contact the Rainbow Tech Support line listed below or to contact your local vacuum cleaner dealer and have them send out a Rainbow Aqua Mate owner’s manual so that you can operate the unit successfully. By listening to the 3 questions listed above the actual water basin I believe is the recovery water tank to be emptied when full and I believe that there is a separately bottle or tank that the solution goes in order to dispense the water. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. The Rainbow / RexAir Factory phone number is listed below: http://rainbowvacuum.com Customer Service 1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST Thanks, Don the Vac Man Go Ahead. Use Us.
little fan first, then hour glasss spacer washer side down then larger fan, with spacer sticking throug then small fan. then normal spacer. assambley starting from top part down, your local vacuum cleaner shop should have switches or contact rainbow, but will be cheaper to go local store
