No television channels on TV, screen says "DTV initial".
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
SOURCE: frozen screen on the dtv
in such cases may restart disconnect and reconnect and if the problem reinside check the local antenna signal may be failing
SOURCE: ''Select DTV channel for OAD'' screen and can't remove
**This is NOT a solution**
I was wondering if you were able to fix this on your own. I am have the exact same issue with a 42LG30
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
I hope that helps.
SOURCE: 26" Insigna LCD TV NS-LCD26-09 (Static)
the signal can be stronger with an signal booster on the splitter...as far as the tv won...its not digital ready you can use this as dvd / wii games only or even monitor for the computer (if the right adapters are purchase)
