Question about Kenmore HE2 Plus Front Load Washer
Type 832 model 11047512601
What is the capacity ?
2 Suggested Answers
SOURCE:
SOURCE: I have a kenmore front loader Model #11047512601
An f21 code indicates that there is something blocking the drainage system. could be something clogging it like mine did. My problem was a washcloth stuck within the drain. My fix was to remove front panel below door using a 1/4" driver to remove 3 screws. You will need a 5 gallon bucket, towels to soak up water, and a pair of channel lock or large pliers to remove drain cap. let remaining water drain into bucket. remove large spring clamp holding rubber boot to drum housing and check to see if anything is in there. that was my fix. good luck
Posted on Dec 18, 2010
What type Of bobbins may be used in a Berlina 1130.
FWIW, genuine Bernina bobbins are frequently better quality than generic--some of the generics are flimsy metal and sometimes bent, misshapen.
Bobbins for Bernina models 832 1004 1090 1120 1130 1230 and others
https://www.sewingpartsonline.com/bernina-1130-sewing-machine-parts.aspx
Mar 18, 2018 | Sewing Machines
Why does it display an 'out of order' message and code F28?
That means the motor control unit has failed and since this is a commercial machine, you may have to call because the part is not available. It lists for about 350 dollars.
Feb 06, 2016 | Whirlpool CHW8990BW CHW8990BW 27"...
My printer drypro model 832 is giving me an error 4122 what should i do the hospital is stuck,my email address is ssekania@gmail.com please help.
My printer drypro model 832 is giving me an error 4122 what should i do the hospital is stuck,my email address is anan4937@gmail.com please help.
Aug 22, 2012 | Konica Minolta Minolta Laser Printers...
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
I have a kenmore front loader Model #11047512601 Type 832 and it will not wring out the clothes proberly I have an f code can you tell us what is wrong please.
Nov 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
53 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
