Question about Mitsubishi VS-60621 60" Rear Projection Television
  • 72 Answers
Re: 60"
Test the electric socket first (with a vacum cleaner...)or and try another one, whitout extension cord.
If thats not solved the problem, test the power cord.
After that only a service. (Or if you can check the power button too)
Posted on Nov 11, 2007
0 characters
3 Points
Problem with Sony KDS-60A2000 60
The power supply regulator board has the fault. There ie no repair to this board. You have to replace it as card basis.
This is the picture of the said power supply board to your Sony TV.2_5_2012_4_35_40_am.jpg
Feb 05, 2012 | Sony KDS-60A2000 60" HDTV
Does not power on
ok on pioneer most of the time it is because of bad connections all over the main power supply board solder these and see what happens like i said most of the times it starts with bad connections.
Nov 18, 2007 | Pioneer PRO-119 60" Rear Projection...
Turned off by itself and never came back what part will I replace
If the TV is completly non-responsive (ie not even a flicker of light on the power button) then one of the first things to check on this is the fuses - easiest being the right corner next to where the power cord plugs in (have to take off the back panel)
May 30, 2009 | Philips 60PP9202 60" Rear Projection...
Hitachi 60ux58b
Let me do some checking and i will get back to you! You still have something open have you ck the pico fuses if one of them is open set will not come on. they look like green resistors but are fuses
Dec 02, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Philips 60p8342 chassy ptv 916
check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Oct 27, 2008 | Philips 60P8341 60" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Same as everyone green light comes on for a couple of seconds than back off!!!
ok, the problem with short detect....
unsolder all convergance ic's and try to turn it on.
does it come on?
if no, check all diods in the power suppy area.
check h-output
does it come on?
also might have a vertical ic.
mmm, check all fuses including the solder in pico fuses.
beleave they are sold green color.
when i get one that comes in they have 1 or 2 blowed pico fuses and that means convergance ics need replaced along with fuses.
good luck!!
Apr 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
No power
It sounds to me that you have a bad HV/Power Supply Board. Before opening the back of the set, always unplug the set from the wall. If you can check electronic components ( ie: transistors, capacitors, fuses etc ) I suggest you check the Horizontal Output Transistor first. If it's not that transistor, check for cold solder joints ( loose connected parts from the printed circuit board ) and re-solder all bad connections. If the set still doesn't work, you may need to seek professional help, as the problem is more deeply laden and you may need to obtain a schematic to repair the set. I hope this has helped. Good luck on your problem.
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Mitsubishi VS-6041 60" Rear Projection...
check 2 5amp chem fuses. in middle of tv. yellow or orange in color . if bad replace the 2 stk convergence ics and fuses.
Nov 06, 2006 | Mitsubishi WS-65809 65" Rear Projection...
Projection Televisions Logo
104 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
