Question about Harman Kardon AVR 130 Receiver
Harmon kardon avr 125 shuts down
My HK 125 shuts down randomly after running for different periods of time. Makes a buzzing, clipping strange sound before shutting down. After turning power button off ( not standby) for some time I can get it to come back on
  • Anonymous Mar 31, 2014
    No sound when turned on. Will come on after an hour or two.
CHECK YOUR WIRING!!! I have had problems from time to time, generally after re-arranging, and have found speaker wires slightly touching on 1 channel caused my AVR to give similar problems. GOOD LUCK!!!
Posted on Mar 04, 2008
  • 72 Answers
If you want to fix it:
It must be a contact problem arount the power switch, power cable, fuse or the condensator area.
Maybe you can se a black color on the board.
And checking the solderind points with a magnifyer can help too.
Thats all from that distence.
Posted on Nov 11, 2007
HK AVR 247 no power up
Could be an open internal fuse or power supply failure.
Sep 19, 2016 | Harmon Kardon Harman Kardon H/k Avr20 Mkii...
HK AVR 125 display strobing and no sound, even in headphone jack
Find someone that does TV or audio repair and have them open it up. A cable assembly may have loosened during the MOVE.
Jan 30, 2014 | Harman Kardon AVR 125 Receiver
Can I connect guitar to my Harmon Kardon receiver
Sorry. They are not compatible. The headphone jack is an output but you need an input for a guitar or bass. You will certainly damage the HK if you continue. There are no compatable inputs on the HK. The inputs are meant to be used with a 300mv output device, such as a CD or DVD.
Oct 02, 2013 | Harman Kardon Audio Players & Recorders
Harmon kardon hk3270 shuts off after only being on about 10 sec
Disconnect speakers and wires. Bad wiring or defective speakers may be loading the amp down and causing the protection circuits inside to disconnect (no sound). If the HK is heating up (beyond what you perceive as normal) with no wires or speakers connected then you have a problem requiring expert repair.
Oct 31, 2012 | Harmon Kardon Harman Kardon HK 3270 65W/CH...
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Trying to connect PS3 to HarmonKardon AVR 310. How?
red and white jacks of the ps3 to tape 1 input at the back of harmon kardon. then select tape 1 on HK to hear sound of the ps3. yes the yellow jack of the ps3 goes to video input of your tv.thenselect video 1 on your tv to see the pic of the ps3
Mar 05, 2010 | Harman Kardon AVR 310 Receiver
Static and popping from Harmon Kardon AVR 340
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Jan 28, 2009 | Harman Kardon AVR 25 MKII
Cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Mar 23, 2008 | Harman Kardon AVR 300 Receiver
Harman Kardon AVR 130 Receiver Logo
503 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
