Watches Logo
J
Joe Barby Posted on Oct 19, 2014
Change a battery in a ILorus by Seiko mickey mouse watch
I have a Lorus by Seiko mickey mouse watch with a dead battery and I tried the "stem out", and accessing the only pry-point (aprox 7 O'clock) and only succeeded in mangling the area with the jewelers screwdriver. This stubborn snap-back has me perplexed. Please advise (that doesn't involve a watch repair shop)
Lorus V422 Mickey Mouse Watch. Why will my watch not keep time after installing a brand new battery?
Question edited for clarity and correct maker spelling.
Question moved to Lorus Category.
Wrong battery with wrong voltage and battery chemistry.
Or dirty contacts to the battery.
https://www.manua.ls/lorus/v422/manual?p=3
https://www.google.com/search?q=lorus+V422+battery
1helpful
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 • Watches
2helpful
Need to replace battery of lorus mickey mouse pocket watch
Try to find a watch repair shop (sometimes called clock & watch shops). Also, many jewelers replace batteries and do watch repair.
2answers
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
I have a Lorus NX11A multifunction watch and have no manual. I have been on the Lorus website but it might as well be written in Japanese
mcdevito75 here, I would imagine this is a Mickey Mouse Lorus watch by the picture supplied. If it Has DAY / DATE function, here"s what to do, --- To set the DAY, pull the stem out to set, keep turning the hads till you rech the day, then push in the stem. To Change the DATE 9 number) slip your fingernail just under the stem and lift it to it"s first position (notch) this should allow you to change the DATE (number) without haveing to turn the hands so many times.
Can't get to work.
I have a lorus rvs001. Silver with black band. The instruction booklet says it takes a SR920W. Seiko Maxell or Sony.
Apr 13, 2009 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
