SOURCE: I'm getting below message everrytime I log on the
this may be because you're not connected to the internet properly, but seeing as though you're able to post here...maybe try installing Firefox
http://www.mozilla-europe.org/en/firefox/
it is faster and safer than Internet Explorer and It's free,i reckon it may fix the problem if not contact your ISP.
SOURCE: I try to log in to facebook and a page comes up
internet ex is probally blocking it.or your firewall.
SOURCE: my faebook says Internet Explorer cannot display
click IE tools select internet options go to connection box than click LAN settings than untick the proxy server your problem is solved Enjoy
SOURCE: When logging in on this one computer it doesn't allow access.
check whether you are in offline mode goto file and uncheck the option workoffline.. if prob persists let me know..
SOURCE: I cannor log into my
If the problem is still persisting then you must try to log on to your facebook id from another system to confirm your account is fine. Then use a good registery cleaner like the advanced system care which is a free download to use for a total clean up. Use a good antivirus to clear off any malwares,.If after all this you are not able to log on then it is possible that some virus/malware had taken files off and corrupted the registery. In this case you will need to try restoring your system to an earlier date by opening control panel choosing backup/restore and do the resetting. If this wont solve the issue you will have to reinstall the OS software on your system, if you have the back up CD use this or otherwise reinstall. This means formatting your main drive , so make sure your files are saved off into other sectors before you attempt. Take help if not familiar so that you can learn in the process. Hope you try. Good day
