Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi 55809 I plugged my tv in and the blue screen came up.  After about a minute I got a bunch of squiggly lines the nothing I have no picture only sound. Thanks in advance
  • jg6423 Nov 11, 2007
    I am not getting anything on the screen no menu, no channel numbers nothing. Any ideas?
  • 72 Answers
Check the cabel TV or antenna conection first. And check the tv with a DVD player or VCR too if work thats a problem.
Some TV forget the settings after a power lost, so try to set the stations again.
Posted on Nov 11, 2007
Blueish hue throughout picture, like a blue ghost a couple of inches to the right of objects on the screen
Your TV's Convergence may be out of line. To adjust this do the following.
1) Press the Menu button on your TV/Remote
2) Scroll through and select the "Advanced Features" Menu.
3) Select Blue Convergence
4) Use the V keys on your remote till the cross hairs are all lined up in the middle of the screen and the center one is white.
4a) You can use the "Video" button to switch between the red & blue cross hairs.
Dec 28, 2010 | Mitsubishi WS-55809 55" Rear Projection...
MITSUBISHI WS55809 Blue Screen
I'm not clear on this. When does it show a blue screen? When you have it in HDTV mode? A Blue Screen means it's not getting a signal (or the signal is very weak, resulting in more static than picture). If it is a blue screen for HDTV, how are you sure the HDTV receiver is working? If you can answer those questions for me, I should be able to track down the problem. I'm not sure which direction to go yet.
Sep 02, 2007 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitsubishi WS-55809. i just came home from vacation and turned on my tv and nothing. the power comes on and nothing comes up on the screen. i tried to scroll through the inputs to make sure it...
Sometimes the convergence IC's failing will cause this. Also, the coolant for the picture tube can leak onto the circuit boards causing damage. Need to have it looked at asap as the coolant problem gets continuously worse.
Jul 29, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809 goes to white foggy screen occasionally
It will cost between 30.00 - 70.00 dollars to do it yourself depending on if you buy the parts seperate or as kit.
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 dark scenes display green lines in background
the crt's pcbs need to be adjusted, screen control is not balanced
Nov 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Picture problem
start checking caps w esr meter probally leakey cap or solder conn.
Apr 21, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsu. 1080 Problem -- Green squiggly lines
if no one answered then hear my thoughts.  odds are it is 2 ic's
I say that because that has been the problem with mine,
except it was the red.  it happened in 2000 when I bought the tv
and just now.  its going to cost me about 400.00 to have someone fix it.  I'm getting it fixed because it's been good to me. I watch dvd's vhs's and laser disks and feel it has plenty of life in it.
good luck
Mar 02, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
