Price removed casing round bobbin and inner case to clean fluff , now I carnt seem to line up properly although all slots back the needle won't go down properly .....husqvarna Viking E10 ..manual not very clear
Remove bobbin case completely and check that the needle will go down properly. If so, put the bobbin case back in lining up the black arrow on the bobbin case (on left hand side) with the metal arm that comes out slightly on the left side. Sometimes, it is tight getting the case back in place properly. Once in place, check that the case will rock back and forth slightly.
Hope this helps.
If you are still having trouble, most Viking dealers will be glad to assist you in the store. You can find the Viking dealer nearest you using Locate a Dealer at the Husqvarna Viking website -
http://www.husqvarnaviking.com/us
It may sound like a silly question,BUT is ur wheel not tightend down to the sew settings? Make sure you NEVER turn that wheel backwards to much.It will strip the gears.Is ur'Bobbin inserted right?I can't think of anything else.SORRY
SOURCE: Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
SOURCE: The bobbin isn't catching on my Viking Husqvarna 190
Your machine is out of time. You'll need to take it in to a professional to get it timed correctly
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, it looks very similar to this Elna so I'm thinking its the same design bobbin and race. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room).
PLEASE NOTE: If you've never pulled this bobbin area apart before, good idea to snap pics with your digital camera as you go to refer to and for reference next time!!
This uncovers the bobbin holder area, you'll see there is a black plastic holder which your bobbin goes into which has the tension device on the side and this then sits inside an outer metal casing which is the hook race. The bobbin holder is held there by a magnet underneath it and sits up against another little stopper. Look at the bobbin case and the stopper, there should be two red marks that must line up. Are they???
If the answer is no, then you need to remove the bobbin case, clean out any lint and fluff using your little brush that came with the machine, and you may also have pieces of thread caught in here too. Once clean, place the bobbin case back into the outer surround, under the other piece and lining up the two red marks. This is where photos are so helpful.
Now replace the needle plate and screws, pressure foot, pop in a new needle and thread everything up again.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've pierced it with the needle several times.
I hope that this helps you out, good luck with your machine.
