Question about Ricoh Aficio 1022 All-In-One Laser Printer
Hello all , i have problem in ricoh af 1022 i get paper jamming in fuse unit haf paper in fuse unit and haf in side in machine .
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Check paper in tray and make sure it was set for correct direction (8.5x11 landscape or portrait).
Posted on Oct 20, 2014
SOURCE:
SOURCE: Ricoh AF-2020 SD problem
how can i get drivers fore this printer
Posted on Sep 08, 2008
SOURCE: ricoh 1022 as network printer?
fdsdfas
Posted on Oct 15, 2008
Joed911
  • 4338 Answers
SOURCE: paper jam in Ricoh Aficio 1515MF
Go to this link, and click on "How to clear misfeed a,p,y"
http://www.ricoh.co.uk/KBase/KBLink.cfm?ProductUID=1878
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 11, 2008
Cogz
  • 1326 Answers
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Posted on Jan 25, 2009
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
Paper jaming in ricoh af 1022 in adf
Paper jams in Ricoh Adfs ( or others), generally have origin in dirty rubber rollers. Oh yes, they can look clean but try to wash them with Benzine and check the cloth! You have to have full traction between the rubber and the paper , otherwise they skew and jam or are not picked up even. Other problem is in the exit (lower ADF side) , a misalignement between adf and the machine body. This can be solved with the mounting screws in the Adf back. Dont forget to have the paper format sensors (top right of ADF) clean and last, you may want to check the horse shoe sensors INSIDE (rear cover ADF). In my lifetime as a Ricoh tech, it only happens this once, and because the machine suffered ADF damage due to Portuguese bumpy roads, Ahahah. I am excluding the obvious, such a paper clip, a stapple, a coin , etc.. This happens very often...
Feb 22, 2014 | Office Equipment & Supplies
I have af 2035/45 ricoh i am facing paper jamming at exit unit. i have done replaced sensors and bicu board and check all related wiring, but couldn,t find solution.
paper jam in aficio hasnt reset . but you must check all doors .it may be one door in your machin is open .more than more right door check it
Apr 27, 2012 | Ricoh Aficio 1035 Copier
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh 1022 service sc544 i need to reset can anyone help
This is a code for the fuser, which indicates a very serious overheating condition. Your machine has something _seriously_ wrong with it, and should be looked at by a service technician.
SC544 - Fusing overheat error 2
A fusing temperature of over 251°C is detected by the fusing temperature monitor circuit in the SBCU board.
Potential Causes:
• Fusing thermistor defective
• Power supply board defective
• SBCU board defective
Oct 29, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
I have problem in ricoh 1022 image repeat problem i cheek fusing drum and replace its still same befor fusing copy ok when enter in fusin then its give the problem what i should do tell me
The problem is that the Upper fixing roller needs to be replaced... Most likely the coating on the roller has worn off and the bear metal is exposed and the toner stick to the metal and reprint it futher dow the page.... It could also be uneven pressure with the upper and lower fixing rollers... It may be a broken bushing or ball bearing... Good Luck
May 03, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 1022 All-In-One Laser Printer Logo
76 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
