Question about Aiwa CDC-X155
Wiring problems I have a aiwa cdc-x155 and i am trying to hook it up to a different car and i need to know what wire is which?
    Brigadier General:
  • 6,966 Answers
Re: wiring problems
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester as against the ground/body of the stereo unit. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Good luck and kind regards.
Posted on Nov 11, 2007
0 characters
3 Points
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
Which wire is the remote wire i'm trying to hook up an amp
The remote wire is blue, or blue white. If it has both, use the blue white.
Aug 17, 2009 | Aiwa CDC-Z127 CD Player
I just go an AIWA CDC-Mp3yu car cd player out of my jeep for my car but the plugs none match i found an adapter for the one with all the wires but cant find adapter for antenna an i need to know what the...
It's most likely a connection for a cd changer unit. you may be able to get an aftermarket cable to run an ipod... cool stuff.
For an antenna adapter... the local stereo stores carry those as well as the wiring harness adapters...
Jun 10, 2009 | Aiwa CDC-MP3 CD Player
I need a wiring diagram for the aiwa stereo harness.
I would like to see a plug for a aiwa car stereo
Mar 30, 2009 | Aiwa CDC-X207 CD Player
Aiwa CDC-X207
hi yellow go in left bottom corner
Jul 12, 2008 | Aiwa CDC-X204 CD Player
Aiwa CDC-X517M Car CD Receiver . . .
The part you are looking for is called the "wiring harness" or sometimes called the "dc cord"
The best way to buy this (and you do need it to use the radio) is to find a local repair center that repairs aiwa car stereos. Ask them if they can order the wiring harness for an Aiwa CDC-X517M. I don't know what Aiwa charges for them, but it should not cost more than about $30 or $40. Some are cheaper and some are a little more.
I did a search for it on google and could not find anything. Very unusual.
The four spots you refer to are the RCA jacks to connect to an external amplifier. 2 are red and 2 are white.
That thing that plugs in above the 15 amp fuse is for your wiring harness.
The circular thing is a din cable jack and that is used for an external CD changer.
Once you get the wiring harness you should take it and the radio to a place that does car stereo installations and they can do the rest for you.
I hope this helps you out, and if it does I would really appreciate a good rating. Most people we help here never rate your help :( and we do most of this for free hoping for a good rating as a thank you for the help :).
Hope you have a great day,
Jun 20, 2008 | Aiwa CDC-X517M CD Player
Home wiring
I don't recommend tampering with any electrical wiring or circuit unless you are experienced and are sure that you know what you are is very easy to make the situation worse.
First and easiest thing would be to check all of the breakers/fuses in the circuit panel. If they use the old fuses, sometimes its hard to tell if these are blown. If you can't tell that any are blown, you may try replacing them one at a time..there may be one burnt out and hard to tell by looking. The only other thing I'd recommend for an armature would be to get a voltage meter and test the output of each fuse (only if you are confident that you know how to properly). You may be able to isolate a line with no current, which could lead you to a bad fuse/breaker, or a bad circuit in the panel.
Any other troubleshooting in my opinion should be done by someone with electrical experience. Hope this helps.
Mar 30, 2008 | Aiwa CDC-X155
red = 12 volts switched (ignition)
yellow = 12 volts constant
black = ground
blue = power antenna
blue/ white = amp turn on
purples = right rear
grays = right front
greens = left rear
whites = right front
black striped speaker wires are negative side
Nov 08, 2007 | Aiwa CDC-X204 CD Player
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Jul 07, 2007 | Aiwa CDC-X217R CD Player
AIWA CDC-x227 CDPlayer
GO to WallMart, Kmart, Radio Shack, etc. and get a new connector adapter (plug)...they're reasonably priced, have them for all make/models of cars, and make installing a car stereo a breeze! When you get the one for your specific car, the wiring instructions are quite easy to follow! :-)
Dec 03, 2006 | Aiwa CDC-X227 CD Player
Car Audio Receivers Logo
218 people viewed this question
Top Aiwa Car Audio Receivers Experts
Custom Exchange
Custom Exchange
buzz flewhart
buzz flewhart
Are you an Aiwa Car Audio Receiver Expert? Answer questions, earn points and help others
