Question about Gateway FPD 1510 15.1" Flat Panel LCD Monitor
Monitor goes black 1 second after coming to full screen
My FPD1530 monitor power light is on but screen has gone black. If I turn the power button off and on again, the screen comes on for 1 second and then goes black again even thought the green power light stays lit. Help?
  • 4 more comments
  • joey07 Nov 27, 2007
    I just started having the same problem today -- after turning my FPD on, it comes on for about a second then goes black. The power light stays on, and if you look at the screen really closely in good light you can see the information on the screen -- it's as if whatever lights up the display shorts out after a second but the monitor itself continues to work.
  • Anonymous Apr 20, 2008
    Same problem. `i find that after 15 minutes of being 'on-but-not-on' if I then shutdown (not restart) and then turn on my computer again it works after a couple of times of turning it off and on.
    Also If you shine a bright torch onto the screen Il bet you can see a very faint image of what you should be seeing.
    ````its something to do with the voltage regulator as far as I can tell, however I cannot crack open my monitor casing to take a look -.-
  • jlapez4 Sep 01, 2008
    Same problem here! I thought that it was due to several power jumps my computer had in my old house but it sounds like more people have the same problem. I had a system for getting it to work also but it won't stay on at all now, just the one second flicker.
  • thucher Dec 02, 2008
    my computer screen goes to black in 1 second after rebooting. Just started yesterday.
  • Anonymous Feb 21, 2009
    My monitor does exactly the same identical thing!!!!
  • Anonymous Apr 18, 2009
    yep same here
Same problem here. Does anybody have an answer?
Posted on Jul 17, 2008
I have 2 systems with the FPD1500 monitor. They worked fine until I applied
SP2. After SP2, they will not start. They come on OK, display the Windows
XP splash screen and then go into sleep mode when the system starts the
proper display mode before the Windows XP login screen is displayed. If I go
into safe mode and uninstall the video adaptor and restart the system, it
will start properly. After it comes up, it finds the video adaptor and
installs it and the session proceeds OK. I can reset the resolution and
number of colors to 1024x768 and Highest (32 colors) and things look fine.
However, when I restart the system, it hangs up after the Windows splash
screen and the monitor goes to sleep.
If I put it into VGA mode, it will come up OK. But once I change any
resolution or number of colors, it imediately goes to sleep.
I would appreciate any help you could offer.
Posted on Aug 26, 2008
Black screen
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
Mar 02, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Corporate Computer
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor comes on for a second then goes off. Power light stays on
You say you can still see the screen if you look close enough. The only thing that gives it more light is the backlight. It is either shorting itself out right after it comes on or the device that powers it (usually the inverter) is the culprit.
Jul 23, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor goes blank less than a second after turning on.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Gateway fpd1530 15in flat
There are more than one inverter circuit for this model. One is prone to have poor solder connections in the transistors Q8 & Q10.
Another can be repaired by replacing 2 1uF electrolytic capacitors near the center edge of the board between the lamp sockets.
Monitor Mike
Nov 15, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway monitor fpd1530
There are multiple curcuits for this model.
Quick turn off of the backlight can be caused by deteriorated solder connectiond on Q6 & Q10 on the power supply/inverter board. Resolder and reassemble. (board mfgr: BI Electronics)
Monitor Mike
Aug 05, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
FPD1530 monitor - no display
I recently fixed 4 fpd1530's with the problem you describe. The fix is to replace capacitors c105 and c106 located on the left side of the power supply board. Both are 1 microfarad 50V parts. The fpd1530 is very easy to work on. Total repair time after initial diagnosis averaged about 10 minutes.
Dec 25, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Gateway FPD 1510 15.1" Flat Panel LCD Monitor Logo
2,166 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
