Question about E-Machines 17F2 17" CRT Monitor
Unclear images My monitor worked fine when I first got it (about 2 years ago). Now everything seems fuzzy and hard to read. Any suggestions?
  • 934 Answers
Re: Unclear images
Remove the rear cover and adjust the focus control on the flyback. Use a non-conductive probe, available as adjustment tools from any radio shack. On the FBT (Flyback Transformer) you have two protruding adjustments - one marked screen, the other focus. The screen adjustment increases the G2 voltage to the crt and brightens the picture by increasing the voltage exponentially. You don't want to adjust the screen voltage. The other is the focus, you can easily turn that clockwise or counter clockwise and watch the screen to set it at your preference.
Hope this helps.
Posted on Nov 11, 2007
0 characters
3 Points
Recently the font on my monitor has become a bit fuzzy, I've tried auto adjust, changing the resolution but they did not help. My motherboard and video card were recently replaced but the person who...
the refresh rate frequency should be 60hz, and monitor resolution 1024 x 768 , should work fine but if the the problem still it might be the lcd monitor getting OLD :) ,you can make sure by connecting the monitor to a different pc and notice the font.
Feb 26, 2010 | Rosewill R700J 17" Flat Panel LCD Monitor
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Acer 1716 17 inch LCD monitor, screen fuzzy w/white lines at rt
Common problem.
There are 8 small VRAM BGA chips.
1 or 2 of them needs REFLOW.
Basically board service.
Dec 16, 2008 | Acer AL1716 17" LCD Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor lcd acer al2016w 20" letters and image are fuzzy,,why?
I also have an Asrock motherboard (M266A) and have the AL2216W. The image and text is also fuzzy. I did improve it a by by unplugging/replugging all of the connectors on the back of the computer. I believe my mouse had a somewhat loose connection and this was causing interference. I can actually create interference on screen by moving my mouse up and down.
These Acer monitors seem to be very sensitive. I also tried this monitor on a old Desktop with Win98 and another new laptop with XP and it looks good on those computers, but not on my Asrock based system.
Nov 30, 2008 | Acer AL2016W 20" LCD Monitor
EMachines TFT LCD Gone Black
I have a E17TR (17") version that a friend gave me (free) a few months back, and just this morning it failed in the exact same way.
My theory is that the image is there but that it is just not being illuminated (so that I can see it). Such a case would suggest a problem with the Backlight or the Inverter.
I have found two web pages (from a company selling LCD repair parts) that can explain better than I.
Hope this help (the pages educated me).
Now if I can just figure out how to open the case; I took out the 4 screws (on the lower end of the back panel), but it just will not open in any way that seems logical . . . .
Feb 02, 2008 | E-Machines eMachines Monitor E15T4
please upgrade your graphics card or the monitor lifes has been came to an end...
Jan 01, 2008 | Gateway FPD1760 17" LCD Monitor
My al 1914 acer monitor is getting fuzzy.
pls set ur pc speakers and and Ups or other adapters which are keeping at the near of ur monitor
Dec 10, 2007 | Acer 19" LCD Monitor
Hi, Using the OSD, select the Auto image adjust.
Sep 15, 2007 | ViewSonic VA703B LCD Monitor
E-Machines 17F2 17" CRT Monitor Logo
170 people viewed this question
Top E-Machines Computer Monitors Experts
buzz flewhart
buzz flewhart
Ricky Ostrom
Ricky Ostrom
Brian Sullivan
Brian Sullivan
Are you an E-Machines Computer Monitor Expert? Answer questions, earn points and help others
