Question about Samsung HCN473W 47" Rear Projection Television
Set won't turn on, timer light flashing and relay clicking
The set first started shading blue and perfect focus would only go as far as 37%. The set then shut down completely and when I turned it back on, the timer light on the front just flashes and I can hear something like a relay clicking in and out as if the t.v. is trying to fire up, but nothing more happens. It just keeps clicking on and off. I purchased a new convergence board from Future Shop and installed it, but it still won't fire up, and it is still flashing and clicking on and off. Any help would be appreciated. I'm hoping maybe it's a fuse or something that burned out in the power supply because of the convergence problem, but I'm stuck at this point. Thanks for your help!!
  • Jetster Nov 11, 2007
    Thanks Bill, I actually bought the complete board with the stks already installed and I just unplugged the old one and plugged the new one in. I kept myself grounded to the set to install the board, but I put the board in and nothing changed. I'm wondering if the feed resistors that you mention are on the convergence board or are they on another circuit board. I was thinking of pulling the board off where the cable tv wire connects to the set. That seems to be where the relay is that is clicking on and off. Does this make any sense?? Thanks a bunch!!
  • 934 Answers
From what your describing the convergence amps, one or both, have probably failed and opened in the convergence circuit. That unit takes two STK392-040 amps and the feed resistors to those amps should be tested as well for any change in value.
For a shop this is a routeen job, we see them every day. But for a layman to tackle it - it could be the repair from hell.
The STK392-040 is both heat and static sensitive, so your $19.95 radio shack special soldering gun could ruin them in a blink of an eye.
They're mounted on the board against a large aluminum heat sink on the signal side of the chassis with heat sink compound and they're a multi-pin IC so they're not that easy to take apart and put in. Lining up all the pins to drop exactly where they're suppose to is a trickey task even for a technician, but then we have a few tricks that experience has taught well...
Call around and ask the shops what they charge for changing-out the convergence amps and testing the feed resistors in that circuit.. I would suggest taking the unit to them and save whatever they charge for a pickup and delivery.
Hope this helps!
Posted on Nov 11, 2007
2 Suggested Answers
  • 395 Answers
SOURCE: auto focus
you will need a service tech to alien the convergence in the service mode then perform the perfect focus in the service mode to lock this setting in memory.
Posted on Jun 21, 2008
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Using the Self-timer on the EOS REBEL T3i.
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
Sep 03, 2017 | Canon EOS Rebel XSi Digital Camera
Will not turn on
check the convergance board for open pico fuses located near the stk amps if they are open the you may have a yolk problem as well. also check the blue gum for cloudy fluid this may be the reason the perfect focus got stuck. if you should get the tv to fire up go to the menu then select reset factory in the convergance menu of the customer menu. this will pull the convegance back to tollorance. the trouble is that when the convegance amps fail customers tend to perfect focus the set and each time they do the convegance memory goes further from tollorance. thus failing the ICs once again. check the pico fuses 1st this is a tell tail sign of those two conditions (yolk, or out of tollorance).
Feb 26, 2008 | Samsung HCM4215W 42" Rear Projection...
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
Timer is lock replace bulb
This set has all kinds of problems--
try the self check:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Jun 01, 2012 | Televison & Video
Most of these sets have a SCREEN/FOCUS block---usually all black with 6 controls----you need to look close at it as one row of 3 will be screen controls---don't touch those----the other 3 will be FOCUS- MARKED in little letters will be r,g,b(red,green blue). TWO ways to adjust the focus: 1. carefully locate the blue focus control and adjust to see if blue will improve in focus. 2. each of the 3 large lens where the picture comes out have a wing nut and a slot--you can loosen the nut and turn the lens---usually best focus that way is if the part that turns is in the middle of the available area to move it.
I should point out that all projection sets intentionally de focus the blue--the lines if blue should be clear but never as perfect as green or red--this is normal.
I do this here for free so if this has been helpful give me a vote here.
if you need direct help:
Aug 20, 2009 | Akai PT5598HD 55" Rear Projection...
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
37mf231d power light flashes on and off will turn on after you keep trying
set the time on your tv and turn off the timer, sleep and wake funtions.
Jun 26, 2008 | Philips Magnavox 27MS343S 27" TV
Hi again,
Did you try connecting the TV into a different power outlet?
Jun 07, 2008 | Televison & Video
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Samsung HCN473W 47" Rear Projection Television Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
