Dryer has just stopped working. Was working fine all the time we have had it, but just stopped.Normal lights come on after setting and pressing start button, but no activation. Have checked lint screen and dryer outlet for obstructions, but none found. Any advice as to what to look for next, or what things normally cause this?
SOURCE: My LG dryer will not power up
You may have a broken door switch. That would be the most likely source of your problem since the machine will not work if the computer senses that the door isn't closed.
SOURCE: dryer will not start.. Here clicking sound when i push start button but nothing happens
Did you clean the lint screen and replace? Also - all lint should be cleaned from back of dryer and the duct...many dryer manufacturer have safety sensors that will not light dryer due to there being too much lint, not enough air flow...(safety feature) ...
SOURCE: whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
SOURCE: Dryer not starting, when I press the start/stop
Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting with Bosch,one you mentioned and no it doesn't depress in, it just resets it...but with the most common there are two thermostat's/switches which could be reset, ( plus a no reset hi-limit on the lint housing not so common )... i.e.
...which cannot be reset, but the hi-limit is the one related to heating you rest already...located on the heater housing and the other (emergency shut off/belt switch) is by the motor shown below.
Anyway,
To save time and back and forth dialog, I`ll mention the most likely and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor I alluded to which will prevent it to start in the event it was tripped for whatever reason. This is the most likely scenario in my opinion based on your post...but again it depends on your model. This will require you to remove the back panel again though. Once you've remove the rear panel, It will look like this image below and all you need to do is push it to the right ( from the back )...
i.e.
Since you`ve already taken the back of the dryer off before to gain access you should have no problem.
Either Scenario I alluded to will require the removal of that panel so let me know if you require further assistance to do this.
The other would be resetting the hi-limit cut out, You can see through the back vent opening when the vent tube is removed ( cannot be removed without removing rear panel the first time, but if attached a certain way can be done each time after ) and then by pushing the red button in...shown below.
i.e.
Keep me posted how you make out or if anything is not clear or if your model is completely different...some have line fuses at the back.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
