Question about Matsonic MS8137C Motherboard
DDR slots gone crazy-switched to SDR-OK
DDR slots gone crazy-switched to SDR-works OK
When on DDR mem,the MBO acts crazy,working flaky and unstable
I know its MBO fault...any suggestions where to dig in MBO? I have know ledge in electronics
  • 175 Answers
If you know how to get into BIOS; restore BIOS to factory defaults and try the DDR RAM again.
Posted on Nov 11, 2007
How to get 2 mem modules to work together
did you buy them as a working pair or individually
they are not compatible
hope this helps
Jul 13, 2012 | Biostar K8M800-M7A Motherboard
My older motherboard has slots for both SDR and DDR ram.I've removed the 256 SDR and replaced with 1 GB DRR, but I'm getting 3 beeps.Perhaps jumpers need to be changed ? What do they look like and where...
Most motherboards no longer have any jumpers for memory, it's auto-detected. Most likely your motherboard doesn't support the size modules you've installed, or you've used an incompatible type. You should check the board manual (usually available from the manufacturer's website) for memory specifications, and be sure yours will work.
Feb 27, 2010 | EliteGroup P4VMM2 Motherboard
Asus a7n266 c mbo has 1,512 ddr pc 3200 .an i add
you have to add memory with the same frequence.DDR 2700 or 3200
Not mixed togheter..
Jan 14, 2010 | ASUS Computers & Internet
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work... keeps a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
Ram compatabilty for k7s5a motherboardand can I run a 1gig of ram with this board
A really unique MB since Each DIMM slot can accommodate DIMMs up to 512 MB in size, although both DDR and SD-RAM are supported, but any one at time, i.e. one among consisting of a bank of 2 DIMM slots(blue pair & black pair having the pairs 2 slots each) for DDR or 2 DIMM slots for DDR or SDR memory cannot be used at the same time. Thus the board supports either 1 GB of PC133 SDRAM, or 1 GB of DDR sdRAM, but not both at the same time.
I hope you got the Catch 22 here !! Nice low costs for doing simple work?
but it's a Catch 22 situation{either choose the Devil or Hell !) ................. sodeep
Oct 25, 2009 | EliteGroup Computers & Internet
Tried to upgrade ram with 2 new pc133 sticks of 256mb ea. Didn't work. What's wrong? Are there switches on the motherboard I need to change? Or something else?
No there are no DIP switches to change, or jumpers to move on your motherboard, in regards to your BIOS recognizing ram memory installed.
(BIOS. Basic Input/Output System. This tiny program, {64MB in size usually}, that is burned into your BIOS chipset, is what recognizes ram memory on your computer)
Things to know about the older Sdram ram memory.
1.It's really SDR Sdram. Single Data Rate Synchronous Dynamic Random Access Memory.
DDR is Double Data Rate Sdram, DDR2 is Double Data Rate 2 Sdram, and so on.
Point? All ram from SDR to DDR3, IS Sdram.
2.Standards have been set by JEDEC for computer ram memory starting from DDR Sdram on up. This standards were not implemented back in the day of SDR Sdram.
Point? Ram memory manufacturers didn't all follow the same standard, and ram memory made for one computer, would Not work in another computer.
This means you need THE ram memory for YOUR eMachines computer.
Main factors when buying SDR Sdram,
A.Correct type. You know this. SDR Sdram.
168 gold plated contact pins on the bottom of the ram 'stick'. (82 on each side)
B.Correct 'Speed'. ('Speed' is slang for Frequency Rate) You know this. SDR Sdram that operates at a frequency rate of 133MHz. (Or also known as PC133)
C.It must be low density Non-ECC ram memory. It cannot be high density ECC. (Error Control Correcting. Used for Server computers mostly)
D.Correct CAS Latency. Also known as Ram Timings. 3-3-3-3-2 would be normal for SDR Sdram.
E.Correct Chip Configuration. How the DRAM chips are accessed. DRAM chips are the black rectangular chips on each side of your ram memory 'stick'. Also what size the DRAM chips are in MegaBytes. (MB)
F.What the Maximum TOTAL Amount is for the motherboard. Is it 256MB? 512MB? Or more?
G.What the Maximum Amount is for EACH ram 'slot'. (Correct speak for 'Slot' is Bank)
H.Do you have four ram 'slots'? You MUST have a ram stick in Slot 1. This is the slot closest to the processor. It is the first ram slot the processor 'reads'.
Jul 12, 2009 | E-Machines eMachines Desktop PC
Ddr ram sdr ram i am same time input that tw0 thats not show two ram capacities just show one ram'' asus p4s533 model please help me
Hi safran0785,
The Asus motherboard, P4S533-MX can run two different types of memory.
(Just not at the same time & in different slots).
You can use 2, 184-pin memory, PC2700/PC2100 MHz or PC1600 up to 2GB. (1GB DIMMs) inserted in the two memory slots closest to the CPU.
Or you can run SDR memory, 168-pin PC133 or PC100MHz DIMMs up to 1GB of memory in the last two slots farthest from the CPU.
You can not run both types of memory at the same time.
The 184-pin DDR PC2700MHz memory is much faster then SDR memory.
The maximum amount of system memory supported is 2GB.
Need more information/questions, just post here.
Good luck safran0785!
Mar 22, 2009 | ASUS P4S533-MX Motherboard
I want to know if SDRAM and DDR@ are the same thing?
No SDRAM is single data ram, with 2 slots in the bottom and DDR is double data ram, with one slot at the bottom.
Aug 17, 2008 | Computers & Internet
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
Matsonic MS8137C Motherboard Logo
78 people viewed this question
Top Matsonic Computers & Internet Experts
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
